MHB Riccati's equation and Bessel functions
The discussion focuses on solving the Riccati differential equation dy/dx = x^2 + y^2, which is not straightforward. It can be transformed into a linear second-order ordinary differential equation (ODE) using the substitution y = -u'/u. The resulting ODE, u'' + x^2 u = 0, can be solved using Bessel functions, specifically yielding solutions involving J and Y Bessel functions. The participants seek further clarification on the steps to derive the solution for y from u. The conversation emphasizes the complexity of the problem and the connection to Bessel functions.
Fernando Revilla
MHB
I quote a question from Yahoo! Answers
How would you go about solving the differential equation dy/dx = x^2 + y^2?
In this case, I have not posted a link there.
Mathematics news on Phys.org
Re: Riccati's equation an Bessel functions
This is the answer I have posted there:
You should specify the exact meaning of 'solving' here. Although we have a
Riccati's equation it is not a trivial problem to find the general solution. It can
be expressed in terms of the $J_n$ Bessel functions of the first kind. Have a
look here.
Does anyone know an alternative?
The non linear first order Riccati ODE...
$$ y^{\ '} = x^{2} + y^{2}\ (1)$$
... can be transformed into a linear second order ODE with the substitution...
$$y = - \frac{u^{\ '}}{u} \implies y^{\ '} = - \frac{u^{\ ''}}{u} + (\frac{u^{\ '}}{u})^{2}\ (2)$$
... so that we have to engage the ODE...
$$u^{\ ''} + x^{2}\ u =0\ (3)$$
At first the (3) may seem ‘simple’ but of course it isn’t... an attempt will be made in next post...
Kind regards
$\chi$ $\sigma$
The solution of the ODE...
$$u^{\ ''} + x^{2}\ u = 0\ (1)$$
can be found in Polyanin A.D. & Zaitzev V.F. Handbook of Exact Solutions for Ordinary Differential Equations, 2nd edition...$$ u(x) = \sqrt{x}\ \{c_{1}\ J_{\frac{1}{4}} (\frac{x^{2}}{2}) + c_{2}\ Y_{\frac{1}{4}} (\frac{x^{2}}{2})\ \}\ (2)$$... where $J_{\frac{1}{4}} (*)$ and $Y_{\frac{1}{4}} (*)$ are Bessel function of the first and second type, $c_{1}$ and $c_{2}$ arbitrary constants. Now computing $y= - \frac{u^{\ '}}{u}$ leads us to the solution of the Riccati's equation...Kind regards $\chi$ $\sigma$
Where is the solution to -u'/u? I need to see the detail steps to arrive at the solution.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
14K
