Richard Perito: Find Quadratic with Roots -1 +/- i√2
In summary, to find the quadratic with roots -1 +/- i√2, we can use the quadratic formula and solve for the coefficients a, b, and c. Having complex roots means that the quadratic equation does not have any real number solutions and can be graphed on the complex plane. While the quadratic with these roots can be factored, the resulting factors will have complex coefficients. There is no shortcut to finding the quadratic with these roots, and the most efficient method is to use the quadratic formula.
MarkFL
MHB
13,288
Here is the question:
Write a quadratic equation with the solution set -1 + i√2, -1 - i√2?
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Richard Perito,
I would begin by writing the roots as:
\(\displaystyle x=-1\pm i\sqrt{2}=\frac{-2\pm\sqrt{-8}}{2}\)
And so from the quadratic formula:
\(\displaystyle x=\frac{-b\pm\sqrt{b^2-4ac}}{2a}\)
we see we have:
\(\displaystyle a=1,\,b=2,\,b^2-4ac=4-4c=-8\implies c=3\)
Hence, the quadratic:
\(\displaystyle f(x)=x^2+2x+3\)
has the given roots.
FAQ: Richard Perito: Find Quadratic with Roots -1 +/- i√2
How do I find the quadratic with roots -1 +/- i√2?
To find the quadratic with these roots, we can use the quadratic formula: x = (-b +/- √(b^2 - 4ac)) / 2a, where a, b, and c are coefficients in the standard form of a quadratic equation (ax^2 + bx + c = 0). Substituting -1 +/- i√2 for x, we can solve for a, b, and c to find the quadratic equation with these roots.
What is the significance of having complex roots in a quadratic equation?
Having complex roots means that the quadratic equation does not have any real number solutions. This can happen when the discriminant (b^2 - 4ac) is negative, indicating that the graph of the quadratic does not intersect the x-axis. In this case, the solutions will be imaginary numbers, in the form of a +/- bi, where a and b are real numbers and i is the imaginary unit (√-1).
Can the quadratic with roots -1 +/- i√2 be factored?
Yes, the quadratic with these roots can be factored using the quadratic formula. However, the resulting factors will have complex coefficients, which may not be useful in certain situations. It may be more practical to leave the equation in its standard form or use the quadratic formula to find the solutions directly.
How can I graph a quadratic with complex roots?
To graph a quadratic with complex roots, we can plot the points on the complex plane. The real part of the complex number will correspond to the x-coordinate, and the imaginary part will correspond to the y-coordinate. We can also use the quadratic formula to find additional points on the graph and then connect them to create a smooth curve.
Is there a shortcut to finding the quadratic with roots -1 +/- i√2?
No, there is no shortcut to finding the quadratic with these roots. The most efficient method is to use the quadratic formula, which will give you the exact equation. Other methods, such as completing the square or factoring, may also work but may involve more steps and could result in an approximation rather than the exact equation.
