MHB Richter Scale Earthquake Magnitude Question?
The discussion revolves around calculating the Richter scale magnitude and energy release of earthquakes using the formula R = (2/3) log(E/E_0). The user seeks assistance in determining the magnitude of an earthquake that releases energy of E = 1000 E_0 and the energy released by a 5.0 magnitude earthquake, given E_0 = 10^{4.40}. They also need to find the energy ratio between an earthquake measuring 8.1 and an aftershock measuring 5.4 on the Richter scale. The calculations lead to various options for the correct answers, prompting the user to identify which one is accurate. The thread emphasizes the application of logarithmic identities in solving these problems.
kjeanch
Hello. I am doing a review sheet for my Pre-Calculus final and one of the questions has me stumped. I'm going through our notes and we never did a problem like this in class. Any help would be greatly appreciated. Thank you.
Find the Richter scale magnitude of an earthquake that releases energy of E= 1000 E_0 . Then find the energy released by an earthquake that measures 5.0 on the Richter scale given that that E_0= 10^{4.40}. Finally find the ratio in energy released between an Earthquake that measures 8.1 on the Richter scale and an aftershock measuring 5.4 on the scale. Use the formula R = 2/3 log E/Eo
A) R = 2, E = 7.94 x 10^{11} joules and the ratio E1/E2 = 10200/1
B) R = 2, E = 7.94 X 10^{10} joules and the ratio E1/E2 = 11200/1
C) R = 2, E = 7.94 X 10^{11} joules and the ratio E1/E2 = 11200/1
D) R = 3, E = 7.94 X 10^{11} joules and the ratio E1/E2 11200/1
E) R = 2, E= 5.94 X 10^{11} joules and the ratio E1/E2 = 11200/1
Which answer would be the correct one?
Mathematics news on Phys.org
We are told to use the formula:
$$R=\frac{2}{3}\log\left(\frac{E}{E_0}\right)\tag{1}$$
For the first earthquake we are given, we are told $E=1000E_0=10^3E_0$. So, plugging this into (1), there results:
$$R=\frac{2}{3}\log\left(\frac{10^3E_0}{E_0}\right)=\frac{2}{3}\log\left(10^3\right)$$
Now, using the identities $\log_a\left(b^c\right)=c\log(b)$ and $\log_a(a)=1$, what do you find for $R$?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
