MHB Rickkyredu's question at Yahoo Answers (shell method for solid of revolution)
The discussion focuses on using the Shell Method to calculate the volume of a solid formed by rotating the area between the curves y=x^5 and y=sqrt[5]{x} around the y-axis. The volume of an arbitrary shell is expressed as dV=2πrh dx, with r=x and h=x^(1/5)-x^5. The limits of integration are determined by finding the intersection points of the two curves, which are x=0 and x=1. The final volume is computed through integration, resulting in V=48π/77. This method effectively demonstrates the application of the Shell Method in calculus.
MarkFL
MHB
Here is the question:
Shell method calculus?
Use the Shell Method to compute the volume of the solid obtained by rotating the region in the first quadrant enclosed by the graphs of the functions y=x^{5} and y=sqrt[5]{x} about the y-axis.
Here is a link to the question:
Shell method calculus? - Yahoo! Answers
I have posted a link there to this topic so the OP may find my response.
Mathematics news on Phys.org
Hello Rickkyredu,
The first thing I like to do in these problems, is look at a graph of the region to be rotated:
Next, I like to compute the volume of 1 arbitrary shell:
$\displaystyle dV=2\pi rh\,dx$
where:
$\displaystyle r=x,\,h=x^{\frac{1}{5}}-x^5$
and so we have:
$\displaystyle dV=2\pi x\left(x^{\frac{1}{5}}-x^5 \right)\,dx=2\pi\left(x^{\frac{6}{5}}-x^6 \right)\,dx$
Next, we need to find the limits of integration, i.e., the $x$-cooridnates of the points of intersection for the two curves:
$\displaystyle x^{\frac{1}{5}}=x^5$
$\displaystyle x^{\frac{1}{5}}-x^5=0$
$\displaystyle x^{\frac{1}{5}}\left(1-x^{\frac{4}{5}} \right)=0$
We can see then:
$x=0,\,1$
Finally, we sum up all the shells by integrating:
$\displaystyle V=2\pi\int_0^1 x^{\frac{6}{5}}-x^6\,dx=2\pi\left[\frac{5}{11}x^{\frac{11}{5}}-\frac{1}{7}x^7 \right]_0^1=2\pi\left(\frac{5}{11}-\frac{1}{7} \right)=\frac{48\pi}{77}$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
