Riemann Integral Identification from Sum
In summary: You can see that the first will approach 1 as n goes to infinity, while the second will not. So I do not think that example works; the endpoints of the sum are not approaching the endpoints of the integral.To answer your question, yes, c_{i} must lie within the subinterval for it to be a Riemann sum. However, this does not necessarily mean that the sum and integral will not give the same value. As n gets larger, more terms will satisfy this condition and the remaining terms will become vanishingly small. So in the end,
Paul245
Hi There Everyone
I am studying undergraduate calculus in first year. My question regards the rules for identifying a limit sum as a Riemann sum and therefore a definite integral. The book we are using says that when choosing [tex] \inline \large c_{i} [/tex] for some [tex] f(x) [/tex], if [tex] \inline \large x_{i - 1} < c_{i} < x_{i} [/tex], then the sum is indeed a Riemann sum for [tex] f(x) [/tex] over an interval.
Allow me to include an example afterwhich I will pose my question in clarity.
Express the limit [tex] \lim_{n \to \infty} \sum_{i=1}^{n} \frac{2}{n} \left( 1 + \frac{2i - 1}{n}\right)^{1/3} [/tex] as a definite integral
Solution:
We want to interpret the sum as a Riemann sum for [tex] f(x)=(1+x)^{1/3} [/tex]. The factor 2/n suggests that the interval of integration has length 2 and is partitioned into n equal subintervals, each of length 2/n. Let [tex] \inline \large c_{i} = (2i - 1)/n [/tex] for i = 1, 2, 3, ..., n. As [tex] n \to \infty, c_{1} = 1/n \to 0 [/tex] and [tex] c_{n} = (2n -1)n \to 2 [/tex]. Thus, the interval is [0, 2], and the points of the partition are [tex] x_{i} = 2i/n [/tex]. Observe that [tex] x_{i-1} = (2i-2)/n < c_{i} < 2i/n = x_{i}[/tex] for each i, so that the sum is indeed a Riemann sum for [tex] f(x) [/tex] over [0, 2]. Since f is continuous on that interval, it is integrable there, and
[tex] \lim_{n \to \infty} \sum_{i=1}^{n} \frac{2}{n} \left( 1 + \frac{2i - 1}{n}\right)^{1/3} = \int_{0}^{2} (1+x)^{1/3} dx[/tex]
My question is, is it necessary for the condition [tex] x_{i-1} = (2i-2)/n < c_{i} < 2i/n = x_{i}[/tex] be met for the sum to be converted to a definite integral. The reason I ask is that as [tex] n \to \infty [/tex] adding or subtracting any constant from the index does not change the sum at infinity in any case because if we choose [tex] c_{i} = (2i- 20000000)/n [/tex] the big number vanishes when [tex] n \to \infty [/tex] so that the sum is the same what ever the big number is. But then [tex] x_{i-1} = (2i-2)/n < c_{i} < 2i/n = x_{i}[/tex] is no longer true and by the definition of a Riemann sum, [tex] c_{i} [/tex] must lie with in the subinterval [tex] [x_{i-1}, x_{i} ][/tex]
You are correct in that changing it the way you described will lead to the correct result, as long as the number is fixed (not dependent on n). As n gets larger, more of the terms will obey condition on ci, and the remaining terms will become vanishingly small. The question is - why bother?
Hi Mathman
Thank you very much for your response.
I agree. But also, our textbook says that for it to be defined as a general riemann sum that [tex] c_{i} [/tex] must be within [tex]
[x_{i-1}, x_{i} ]
[/tex]
The following two limits produce the same answer but the last one does not satisfy the need for [tex] c_{i} [/tex] to be with in the partition subinterval. Does that mean I am wrong in assuming that [tex] c_{i} [/tex] must lie with in the subinterval for it to be a Riemann sum? Or is it that it does not need to be a Riemann sum to calculate the area or function as a definite integral? Or am I no where near the mark?:
[tex]
[/tex]
[tex]
c_{i} = \frac{2i - 1}{n} ,\
\Delta x_{i} = \frac{2}{n},\
x_{i} = \frac{2i}{n}
x_{i-1} = \frac{2(i-1)}{n},\
x_{i-1} < c_{i} < x_{i}
[/tex]
condition for Riemann sum is satisfied
[tex]
\lim_{n \to \infty} \sum_{i=1}^{n} \frac{2}{n} \left( 1 + \frac{2i - 100000}{n}\right)^{1/3}
[/tex]
[tex]
c_{i} = \frac{2i - 100000}{n},\
[/tex]
condition not satisfied.
Paul245 said:
Hi Mathman
[x_{i-1}, x_{i} ]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
Let's look at just the part in parentheses. In the first example, it is
[tex]\left(1 + \frac{2i-1}{n}\right)[/tex]
and "plugging" in the endpoints of the sum, namely [tex]i = 1[/tex] and [tex]i = n[/tex] gives (1 + 1/n) and (3 - 1/n), which is consistent with your integral bounds for each n.
In the second example, you have
[tex]\left(1 + \frac{2i - 100000}{n}\right)[/tex]
andif we again plug in the endpoints [tex]i = 1[/tex] and [tex]i = n[/tex] , we get 1-(99998/n) and 3-(100000/n).
Thus for each n, you are covering a very different interval, starting way over at [-99997,-99997], (of zero length?!) and while this interval eventually slides over or "converges" to [1,3] and, because of the continuity of (1+x)^1/3, in the limit you might even get the right answer (though I'm not fully convinced of that - you would have to argue this rigorously), this is by no means a Riemann sum, nor could you expect this to work in general.
For example, what if the exponent had been 1/2 instead of 1/3? Then most of the terms of the sum wouldn't even be defined!
Definition of a Definite Integral
Hi
Subject Change to: Definition of a definite Integral
Thank you for your response. I've been thinking about your post and I understand now that the Riemann sum itself can never be defined if [tex]
c_{i}
[/tex] does not lie within [tex]
[x_{i-1}, x_{i} ]
[/tex]. However, the textbook that we are using says that a definite integral is defined by the limiting case of a Riemann sum. But by the fact that you can reach the definite integral by the limit of a sum that is not a Riemann sum, the conclusion must be that the limiting case of a Riemann sum is not a definitive definition for the definite integral.
Paul245 said:
Hi
c_{i}
[x_{i-1}, x_{i} ]
That much is certainly true. There are a number of different definitions for the definite integral. (An author named Frank Burk has even written a book called "A Garden of Integrals" that discusses a number of them.) Some definitions are equivalent, whereas others are more powerful than the Riemann integral because they can integrate all Riemann-integrable functions and then some. (And, a fact of key importance, they produce the same answer as the Riemann integral for those functions that are Riemann integrable.)
The Lebesgue integral, for example, is usually used in analysis instead of the Riemann integral, not only to be able to integrate more functions, but because more manipulations involving the exchange of limit and integral are valid. It also generalizes to abstract spaces, making it a natural choice for probability theory, for example.
Then there's the Henstock-Kurzweil ("gauge") integral which on the surface appears to be a trivial modification of the Riemann definition in which, loosely speaking, the [tex]\delta[/tex] that specifies the maximum rectangle width in the Riemann sum is allowed to vary across the interval of integration. If my understanding is right, this simple change produces an integral that is even more powerful than the Lebesgue integral.
FAQ: Riemann Integral Identification from Sum
1. What is the Riemann Integral?
The Riemann Integral is a method of calculating the area under a curve by dividing it into smaller rectangles and adding up their areas. It is a fundamental concept in calculus and is used to solve various problems in mathematics and physics.
2. How is the Riemann Integral identified from a sum?
The Riemann Integral is identified from a sum by taking the limit of a sum of infinitely many rectangles as their width approaches zero. This limit is known as the Riemann sum and it converges to the Riemann Integral, providing the exact value of the area under the curve.
3. What is the difference between the Riemann Integral and the Lebesgue Integral?
The main difference between the Riemann Integral and the Lebesgue Integral is the approach they use to calculate the area under a curve. The Riemann Integral uses rectangles to approximate the area, while the Lebesgue Integral uses more complex shapes called measurable sets. The Lebesgue Integral is more general and can handle a wider range of functions than the Riemann Integral.
4. What are the applications of the Riemann Integral?
The Riemann Integral has numerous applications in mathematics, physics, and engineering. It is used to calculate the work done by a force, the distance traveled by an object, and the total energy of a system. It is also used in probability and statistics to calculate the probability of an event and the expected value of a random variable.
5. What are the limitations of the Riemann Integral?
One of the main limitations of the Riemann Integral is that it can only be applied to functions that are continuous over a closed interval. It also requires the function to be integrable, meaning that it must have a finite number of discontinuities. Additionally, the Riemann Integral may not give accurate results for highly oscillating functions or functions with infinite discontinuities.
