Riemann's theorem for complex series
In summary, a famous theorem of Riemann states that for a conditionally convergent series of real numbers, the set of all sums of rearrangements of the series is equal to the set of real numbers. This result has been extended to Banach spaces, but the focus here is on complex series. It has been shown that for a conditionally convergent series of complex numbers, the set of all sums of rearrangements is an affine subspace of the complex plane. This can be proven by constructing a series with terms {a_k} such that the set of all sums of rearrangements is the desired subspace. A lemma is used to prove the affinity of the subspace, which states that any complex number not
zpconn
243
Suppose the real numbers {a_k} are the terms of a conditionally convergent series. Let C({a_k}) denote the set of all sums of rearrangements of this series. A famous theorem of Riemann shows that, in this particular circumstance, C({a_k}) = R, the set of real numbers.
Various generalizations of this result exist for Banach spaces, but I'm interested in the special case of complex series. In particular, if the complex numbers {a_k} are the terms of a conditionally convergent series, then C({a_k}) is an affine subspace of the complex plane.
I was told this informally by a professor, but the result is completely fascinating to me, so I've been trying to find a proof, either online or by working one out myself. Well, so far I have failed in both endeavors!
I was wondering if anyone had any insight into this problem, either a reference or an idea on how to proceed in proving it.
One thing to note is that given an affine subspace of the plane, one can construct a series with terms {a_k} such that C({a_k}) is that particular subspace. For instance, if {alpha,beta} is a basis of the complex plane and {a_k} and {b_k} are *real* numbers that are the terms of two conditionally convergent series, then C({alpha * a_k + beta * a_k}) is the plane by Riemann's theorem as stated above for series with real terms.
In short, it's evident that any affine subspace can be achieved in the form C({a_k})--the significant part is that C({a_k}) must always have this form! (Of course, this is provided that the associated series is conditionally convergent.)
A convergent rearrangement of a_k determines that of b_k.The latter may not converge. Although your guess is right, we can't work with individual components.
Here's a lemma which will prove the affinity of the subspace.
Lemma : Let {c_n} be a conditionally convergent series ,with two rearrangements A & B converging to distinct complex numbers a,b. Then the series can be made to converge to ka+(1-k)b for any real number k.
Here's why it works. Select a partial sum of A, which is close to a. The partial sums of B which include this partial sum eventually tend to b . Thus, we can 'move' along the direction a-->b ( back & forth by repeted selection) & generate the line.
Suppose that complex number c not on this line is in C{c_n}. We can apply the lemma once more to infer that the range is ka+lb+mc for any real numbers k,l,m with
k+l+m =1. This subspace is clearly the complex plane. (Essentially, if c c joined to every point on line a--b, the plane is spanned).
The generalisation to real vector spaces follows similarly.
Related to Riemann's theorem for complex series
What is Riemann's theorem for complex series?
Riemann's theorem for complex series is a mathematical theorem that states that if a series of complex numbers converges absolutely, then it also converges when the terms are rearranged in any order.
What is the significance of Riemann's theorem for complex series?
Riemann's theorem for complex series is significant because it ensures that the order in which the terms of a convergent complex series are added does not affect the final result. This allows for more flexibility in mathematical calculations involving complex series.
How is Riemann's theorem for complex series different from the Riemann rearrangement theorem?
Riemann's theorem for complex series is a special case of the more general Riemann rearrangement theorem, which applies to all series of real or complex numbers. However, Riemann's theorem for complex series only applies to series that converge absolutely, while the Riemann rearrangement theorem applies to any convergent series.
What is an absolutely convergent series?
An absolutely convergent series is a series in which the sum of the absolute values of the terms converges. In other words, the series converges when the negative signs of the terms are ignored. Riemann's theorem for complex series only applies to absolutely convergent series.
How is Riemann's theorem for complex series used in mathematical proofs?
Riemann's theorem for complex series is often used in mathematical proofs to rearrange terms in a series and show that the resulting series still converges. This can simplify calculations and make proofs more elegant. It is also a useful tool in the study of complex analysis and its applications.
  • Math Proof Training and Practice
