Right Hand Rule Associated Question
In summary, the two wires shown in the diagram will repel each other. This is because the magnetic field created by the bottom wire will exert a force on the top wire, according to the right hand rule. This force will cause the wires to repel each other. This is a question about magnetic fields, not electric fields, and answering the two questions can help to explain this phenomenon.
Fizickstudent
What will happen to the two wires shown in the diagram (in the attachments)?
A: nothing will happen
B: repel each other
C: attract each other
The answer is "B", they will repel each other.
I thought it would attract because the current in the two wires are coming in from different directions/ sides signifying that the electric fields are not the same, and if the electric fields are different then there must be an attraction.
But that was just my guess, could someone tell me why the two wires repel each other instead of attract each other?
  • Right Hand Rule.doc
This is a question about magnetic fields, not electric fields.
Answer these:
(1) What is the magnetic field created by the bottom wire? (Use a right hand rule.)
(2) What force does that magnetic field exert on the top wire? (Use a right hand rule.)
The right hand rule states that when two currents are flowing in parallel wires in the same direction, they will repel each other. This is because the magnetic fields produced by the currents will interact and create a force between the wires that pushes them away from each other. This is also known as the "Lorentz force".
In this case, the currents in the two wires are flowing in the same direction, as shown by the arrows in the diagram. Therefore, according to the right hand rule, they will repel each other. On the other hand, if the currents were flowing in opposite directions, they would attract each other instead.
The reason for this is that when the currents are flowing in the same direction, the magnetic fields produced by each current are in the same direction. This creates a force that pushes the wires away from each other. However, when the currents are flowing in opposite directions, the magnetic fields produced are in opposite directions, which creates a force that pulls the wires towards each other.
So in summary, the two wires repel each other because the currents are flowing in the same direction, which creates magnetic fields that interact and produce a repulsive force between the wires.
Related to Right Hand Rule Associated Question
1. What is the Right Hand Rule and why is it important in science?
The Right Hand Rule is a method used to determine the direction of magnetic fields and electric currents in three-dimensional space. It is important in science because it helps us understand how magnetic fields and electric currents interact with each other and how they affect the motion of charged particles.
2. How do you use the Right Hand Rule to determine the direction of a magnetic field?
To use the Right Hand Rule to determine the direction of a magnetic field, you must align your right hand with the direction of the current or the direction of motion of a positive charge. Your thumb will then point in the direction of the magnetic field.
3. Can the Right Hand Rule be used to determine the direction of an electric current?
Yes, the Right Hand Rule can also be used to determine the direction of an electric current. You must align your right hand with the direction of the current and your fingers will then curl in the direction of the magnetic field.
4. What is the difference between the Right Hand Rule and the Left Hand Rule?
The Right Hand Rule is used to determine the direction of magnetic fields and electric currents while the Left Hand Rule is used to determine the direction of forces acting on charged particles in a magnetic field.
5. How is the Right Hand Rule used in practical applications?
The Right Hand Rule is used in many practical applications such as designing motors, generators, and other electromagnetic devices. It is also used in fields such as physics, engineering, and astronomy to understand and analyze the behavior of magnetic fields and electric currents.
