Right Triangle: Proving It's a Right Triangle
In summary, the sides $x,\,y,\,z$ of a triangle satisfy the equality $(x^4+y^4+z^4)^2=2(x^8+y^8+z^8)$ and it has been proven to be a right triangle.
anemone
MHB
POTW Director
3,883
115
The sides $x,\,y,\,z$ of a triangle satisfy the equality $(x^4+y^4+z^4)^2=2(x^3+y^3+z^3)$.
Prove that it's a right triangle.
Mathematics news on Phys.org
A point of confusion:
I suppose I am probably missing something, but if \(\displaystyle x=y=z=\left(\dfrac23\right)^{\dfrac15}\) then
\(\displaystyle (x^4+y^4+z^4)^2=2(x^3+y^3+z^3)\) and the triangle is equilateral.:confused:
Hi greg1313,
I think I should have mentioned that all three of them $x,\,y,\,z$ aren't equal.
Can one of the sides be negative?
Hi RLBrown,
No, all $x,\,y,\,z$ are supposed to be all different real positive numbers.:)
Hi MHB,
I want to apologize for the second time in a row today(Tmi) as I also made a typo in this challenge, the problem should read:
The sides $x,\,y,\,z$ of a triangle satisfy the equality $(x^4+y^4+z^4)^2=2(x^8+y^8+z^8)$.
A special thanks to Opalg for letting me know about the typo that I had made in the original stated problem.(Nod)
Here is my solution. I think there are more elegant approaches.
The notation is symmetric, so it´s OK to let: $z^2 = x^2+y^2$. I also assume: $z >0$.
I need to prove, that the equation holds.
\[(x^4+y^4+z^4)^2 = 2(x^8+y^2+z^8)
\\\\\Rightarrow \left ( \left ( \frac{x}{z} \right )^4+\left ( \frac{y}{z} \right )^4+1\right )^2=2\left ( \left ( \frac{x}{z} \right )^8+ \left (\frac{y}{z} \right )^8 +1\right )\]
To ease the notation let $a = \frac{x}{z} = cos\alpha$ and $b = \frac{y}{z}=sin\alpha \;\;\; 0<\alpha<\frac{\pi}{2}$ .
I will be using the relation: $a^2+b^2 = 1$ several times:
\[2(a^8+b^8+1)=(a^4+b^4+1)^2 \\\\ \Rightarrow 2(a^8+b^8)+2-(a^8+b^8+2a^4b^4+2(a^4+b^4)+1)=0 \\\\ \Rightarrow a^8+b^8-2a^4b^4-2(a^4+b^4)+1=0 \\\\ \Rightarrow (a^4-b^4)^2-2((a^2+b^2)^2-2a^2b^2)+1=0 \\\\ *\Rightarrow (1-2b^2)^2-2(1-2(1-b^2)b^2)+1=0\\\\ \Rightarrow 1-4b^2+4b^4-2 +4(1-b^2)b^2+1=0\\\\ \Rightarrow 1-4b^2+4b^4+4b^2-4b^4-1 = 0
\\\ \Rightarrow 0=0.\]
This confirms that the sides $x,y$ and $z$ are sides in a right triangle.
\[(*). \;\;\; a^4-b^4 = (1-b^2)(1-b^2)-b^4 = 1-2b^2\]
Good work, but I'm not sure that proves there are not other values for $x$, $y$ and $z$ for which the equation holds.
Thanks for participating in this challenge, lfdahl, and like greg1313, I'm also less sure that your method is conclusive enough. :(
Here is my solution though::)
Note that
$\begin{align*}(x^2+y^2+z^2)(x^2+y^2-z^2)(x^2-y^2+z^2)(x^2-y^2-z^2)&=(x^4+2x^2y^2+y^4-z^4)(x^4-2x^2y^2+y^4-z^4)\\&=(x^4+y^4-z^4+2x^2y^2)(x^4+y^4-z^4-2x^2y^2)\\&=(x^4+y^4-z^4)^2-4x^4y^4\\&=(x^4+y^4+z^4-2z^4)^2-4x^4y^4\\&=(x^4+y^4+z^4)^2-4x^4y^4-4x^4z^4-4y^4z^4\\&=(x^4+y^4+z^4)^2-2((x^4+y^4+z^4)^2-x^8-y^8-z^8)\\&=2(x^8+y^8+z^8)-(x^4+y^4+z^4)^2\end{align*}$,
This tells us $(x^4+y^4+z^4)^2-2(x^8+y^8+z^8)=(x^2+y^2+z^2)(x^2+y^2-z^2)(x^2-y^2+z^2)(x^2-y^2-z^2)$
Since $x^2+y^2+z^2\ne 0$, we get either $x^2+y^2-z^2=0$, $x^2-y^2+z^2=0$ or $x^2-y^2-z^2=0$, which in turn suggest that $x,\, y,\, z$ can form the sides of a right-angled triangle.
Hi anemone,
It looks like we both like factoring. :cool: I had the same factoring idea, but I took slightly different steps. Namely, I let $u = x^2, v = y^2, w = z^2$, and write
$$2(u^4 + v^4 + w^4) - (u^2 + v^2 + w^2)^2$$
$$ = (u^4 + v^4 + w^4 + 2u^2v^2 - 2v^2w^2 - 2w^2u^2) - 4u^2v^2$$
$$ = (u^2 + v^2 - w^2)^2 - (2uv)^2$$
$$ = (u^2 + v^2 - w^2 - 2uv)(u^2 + v^2 - w^2 - 2uv)$$
$$ = [(u - v)^2 - w^2][(u + v)^2 - w^2]$$
$$ = (u - v - w)(u - v + w)(u + v - w)(u + v + w)$$
Reverting back to the $x$, $y$, and $z$ variables, we get the same thing.
Euge said:
Hi anemone,
Wow, Euge! Your method is definitely neater and more elegant than mine! I therefore have learned something valuable from your solution! :)
FAQ: Right Triangle: Proving It's a Right Triangle
What is a right triangle?
A right triangle is a type of triangle that has one angle measuring 90 degrees. This angle is called the right angle, and it is formed by the intersection of the two shorter sides of the triangle.
How do you prove that a triangle is a right triangle?
There are several ways to prove that a triangle is a right triangle. One way is to use the Pythagorean theorem, which states that the square of the length of the hypotenuse (the longest side) is equal to the sum of the squares of the other two sides. If this equation holds true for a given triangle, then it is a right triangle.
Can you prove a right triangle without using the Pythagorean theorem?
Yes, there are other methods for proving that a triangle is a right triangle. These include using trigonometric ratios (such as sine, cosine, and tangent) or the properties of special right triangles (such as the 30-60-90 or 45-45-90 triangles).
What are some real-life applications of right triangles?
Right triangles are commonly used in various fields, such as engineering, architecture, and navigation. They are also used in everyday situations, such as measuring the height of a building or calculating the slope of a ramp.
What is the importance of proving a triangle is a right triangle?
Proving that a triangle is a right triangle not only confirms the properties of the triangle but also allows for the use of various mathematical formulas and relationships that are specific to right triangles. This can be useful in solving various problems and applications involving right triangles.
