Rigid Body Problem Involving a Tilted Rotating Disc
In summary: So, I'll give your method a try. Thanks.In summary, the conversation discusses the calculation of angular momentum and kinetic energy for a rotating disk using different equations. The correct method is to calculate the moment of inertia tensor and project it onto the rotation axis to obtain the effective moment of inertia. This approach may be more advanced for introductory physics and an alternative method of calculating the total angular momentum as the sum of two components is suggested.
Peter564
A uniform disc of radius 0.1 m and mass 0.4 kg is rotating with angular velocity 1 rad s−1 about
an axis at 45◦ to its plane through its centre of mass. What is
(a) its angular momentum, and (b) its kinetic energy?
(You may assume the centre of mass is stationary.)
L=(1/2)mr^2w KE=(1/2)Iw^2
I=(1/2)mr^2
Using these equations, I find L=0.02Nms, I=0.02Kgm^2 and KE=10mJ
However, i don't think that this is the right method here.
:welcome: !
Peter564 said:
L=(1/2)mr^2w
Using these equations I get something else. Check your calculations ...
why ?
BvU said:
why ?
Because of that 45° angle. ##I## will not be ##\frac 12mr^2##
Peter564 said:
What is
Are you supposed to find the angular momentum vector ## \vec L## relative to an origin at the center of the disk?
Or, are you supposed to find just the component of ##\vec L## along the axis of rotation?
Peter564 said:
Homework Statement:: A uniform disc of radius 0.1 m and mass 0.4 kg is rotating with angular velocity 1 rad s−1 about
Relevant Equations:: L=(1/2)mr^2w KE=(1/2)Iw^2
I=(1/2)mr^2
It is not the right method. The moment of inertia ##I=\frac{1}{2}mR^2## is about an axis that is perpendicular to the disk and passes through its center. The axis here is not perpendicular to the plane of disk but inclined at 45° from it.
Likes Lnewqban
There should be a moment about the center of mass, which plane of action rotates with the disc.
If the OP question is a test after learning about the moment of inertia tensor, I will suggest writing up that matrix using principal coordinates and project it onto the rotation axis expressed in that coordinate system to get the effective moment of inertia around that axis. That is the general approach anyway.
Edit: removed unnecessary step about rotating before projection.
Angular momentum is a vector.
If the disk is rotating about an an axis perpendicular to the plane of the disk, the angular momentum vector is ##~\mathbf{L}_{\perp}=I_{\perp}{\omega~}\mathbf{\hat e}_{\perp}.##
If the disk is rotating about an an axis parallel to the plane of the disk, the angular momentum vector is ##~\mathbf{L}_{\parallel}=I_{\parallel}{\omega~}\mathbf{\hat e}_{\parallel}.##
What is ##~\mathbf{L}_{\text{tot}}=\mathbf{L}_{\perp}+\mathbf{L}_{\parallel}##?
If ##\omega## is the angular speed around the tilted axis then surely this yields too large a result?
I would just write it as ##\mathbf{L} = \mathbf{n}^T \, \mathbf{I} \, \mathbf{n} \, \omega##, where ##\mathbf{n}## is the rotation unit axis and ##\mathbf{I}## is the 3x3 moment of inertia, which is very simple to write up if principal coordinates are selected.
I am not sure about that if the relation between your ##\mathbf{\hat n}## and my ##\mathbf{\hat e}_i## is something like ##\mathbf{\hat n}=\mathbf{\hat e}_{\parallel}\cos\!\varphi+\mathbf{\hat e}_{\perp}\sin\!\varphi##. Your approach is certainly simple but probably above the level of introductory physics. The disk here is rotating about two perpendicular axes with the same angular speed. Therefore, it should be easy to explain to someone who has seen vectors but not tensors that the total angular momentum can be viewed as the resultant of two components that can be calculated separately.
Yes, that is my notion of the effective rotation axis. The two approaches do seem to equal each other if the ##\cos\varphi## and ##\sin\varphi## factors are included in the parallel and perpendicular angular momentum vectors since this then corresponds to ##\omega## projected onto the parallel and perpendicular axis, respectively.
Likes kuruman
FAQ: Rigid Body Problem Involving a Tilted Rotating Disc
What is a rigid body in the context of a tilted rotating disc?
A rigid body is an object with a fixed shape that does not deform under stress. In the context of a tilted rotating disc, it means the disc maintains its shape and size while rotating, and all points on the disc move in a predictable manner based on its rotation and tilt.
How does the tilt angle affect the rotation of the disc?
The tilt angle of the disc affects the orientation of the rotational axis relative to a reference frame, such as the ground or another fixed axis. This tilt can introduce additional components of angular velocity and can affect the stability and dynamics of the rotation, including precession and nutation behaviors.
What are the equations of motion for a tilted rotating disc?
The equations of motion for a tilted rotating disc are derived from Newton's laws and Euler's rotational equations. They typically involve the angular velocity vector, the moment of inertia tensor, and external torques. The general form is given by Euler's equations: \( \mathbf{I} \frac{d\boldsymbol{\omega}}{dt} + \boldsymbol{\omega} \times (\mathbf{I} \boldsymbol{\omega}) = \mathbf{T} \), where \( \mathbf{I} \) is the moment of inertia tensor, \( \boldsymbol{\omega} \) is the angular velocity vector, and \( \mathbf{T} \) is the external torque.
What is the significance of gyroscopic effects in a tilted rotating disc?
Gyroscopic effects are significant in a tilted rotating disc because they influence the stability and behavior of the disc's rotation. These effects arise due to the conservation of angular momentum and can cause the disc to exhibit precession (a slow change in the orientation of the rotational axis) and nutation (a wobbling motion superimposed on the precession).
How can one experimentally observe and measure the dynamics of a tilted rotating disc?
Experimentally observing and measuring the dynamics of a tilted rotating disc can be done using high-speed cameras to track markers on the disc, gyroscopes to measure angular velocity, and accelerometers to measure forces and torques. Data acquisition systems can record these measurements, and software can analyze the data to determine the disc's motion characteristics and validate theoretical models.
