Ring Homomorphisms from Z to Z .... Lovett, Ex. 1, Section 5.
In summary: What do you get for an arbitrary ##f(z)## in those cases?In summary, Peter attempted to solve an equation for a ring homomorphism but was not successful. He then suggested playing with properties in Section 5.4.1 to see if he could find a requirement for the homomorphism.
Math Amateur
MHB
3,998
48
I am reading Stephen Lovett's book, "Abstract Algebra: Structures and Applications" and am currently focused on Section 5.4 Ring Homomorphisms ...
I need some help with Exercise 1 of Section 5.4 ... ... ...
Exercise 1 reads as follows:
The relevant definition in this case is as follows:
Thoughts so far ... ...
One ring homomorphism ##f_1 \ : \ \mathbb{Z} \rightarrow \mathbb{Z}## would be the Zero Homomorphism defined by ##f_1(r) = 0 \ \forall r \in \mathbb{Z}## ...
(##f_1## is clearly a homomorphism ... )
Another ring homomorphism ##f_2 \ : \ \mathbb{Z} \rightarrow \mathbb{Z}## would be the Identity Homomorphism defined by ##f_2(r) = r \ \forall r \in \mathbb{Z}## ...
(##f_2## is clearly a homomorphism ... )
Now presumably ... ... ? ... ... ##f_1## and ##f_2## are the only ring homomorphisms from ##\mathbb{Z} \rightarrow \mathbb{Z}## ... ... but how do we formally and rigorously show that there are no further homomorphisms ... ...
Hope that someone can help ...
Peter
I think the crucial part is the image of ##\pm 1## under a ring homomorphism ##f##. Try to investigate whether it can be other than ##0## or ##\pm 1##. If not, then you have to show, that either ##f=f_1=0## or ##f=f_2=id_\mathbb{Z}##.
Assume you have ##f## and play with the properties in 5.4.1 to get some requirements for ##f##.
Likes Math Amateur
Hi fresh_42 ...
Tried the following but no luck so far ...
Suppose ##\exists \ f_3 \ : \ \mathbb{Z} \rightarrow \mathbb{Z}## ... ... try to show no such ##f_3## different from ##f_1 , f_2## exists ... ...
Let ##f_3(2) = x## where ##x \in \mathbb{Z}## ...
Then ##f_3(4) = f_3( 2 \cdot 2 ) = f_3( 2) f_3( 2) = x^2##
and
##f_3(4) = f_3( 2 + 2) = f_3( 2) + f_3( 2) = x + x = 2x##
Then we must have ##x^2 = 2x## ... ... ... (1)
I was hoping that there would be no integer solution to (1) ... but ##x = 0## satisfies ... so ... problems ..Was that the kind of approach you were suggesting ... ?
Peter
Yes, only that I would have used ##1## instead of ##2##.
You have now ##f_3(2) \in \{0,2\}##. But what is ##f_3(y)## in those two cases? As ##\pm 1## are the only units, it might help to look at ##f(1\cdot z)##.
Math Amateur said:
Hi fresh_42 ...
and
Peter
============================================================================OK thanks fresh_42 ...
Following your suggestion ... ... Let ##f_3(1) = x## where ##x \in \mathbb{Z}## ...
##f_3(2) = f_3( 1 + 1) = f_3( 1) + f_3( 1) = x + x = 2x##
and we have ##f_3(2) = f_3( 2 \cdot 1 ) = f_3( 2) f_3( 1) = 2x \cdot x = 2x^2##
Then we must have ##2x^2 = 2x## ... ... ... (1)
That is, ##x^2 = x## where ##x \in \mathbb{Z}## ... ... so ##x = 0## or ##x = 1## ...
BUT ... where to from here ...Note ... can you explain how you got ##f_3(2) in \{ 0, 2\}## ... ?Hope you can help ...
Peter
Math Amateur said:
Note ... can you explain how you got ##f_3(2) \in \{ 0, 2\}## ... ?
From your equation.
This means ##x^2-2x=x(x-2)=0## and since ##\mathbb{Z}## is an integral domain, if follows that either ##x=0## or ##x=2##.
I think ##0=f(1 \cdot a)-f(a)=f(a)(f(1)-1)## would have been shorter, but o.k. So we have ##f(1)=x \in \{0,1\}##.
Make two cases now: a) ##f(1)=0## and b) ##f(1)=1##. What do you get for an arbitrary ##f(z)## in those cases?
Likes Math Amateur
fresh_42 said:
From your equation.
Thanks fresh_42 ... all clear now ...
We have for a ring homomorphism ##f \ : \ \mathbb{Z} \rightarrow \mathbb{Z}##
... either ...
(a) ##f(1) = 0##
or
(b) ##f(1) = 1##Now it is clear that if ##f## is a ring homomorphism such that ##f(1) = 0## ...
then we must have ##f(r) = 0 \ \forall \ r \in \mathbb{Z}## ...
and ...
... if ##f## is a ring homomorphism such that ##f(1) = 1## ...
then we must have ##f(r) = r \ \forall \ r \in \mathbb{Z}## ...Therefore there are only two ring homomorphisms ##f \ : \ \mathbb{Z} \rightarrow \mathbb{Z}##Thanks for all the help ...
Peter
Math Amateur said:
(a) ##f(1) = 0##
A
Math Amateur said:
(b) ##f(1) = 1##
B
Yes, but which is the equation placed at A and B which supports the conclusion? What is the step from ##f(1)## to ##f(r)##?
Likes Math Amateur
fresh_42 said:
AB
Hi fresh_42 ...
So, I will do the "proof" informally ... to do it formally we would simply use mathematical induction ... but the informal proof demonstrates what is going on ...Case A
For a ring homomorphism ##f \ : \ \mathbb{Z} \rightarrow \mathbb{Z}## we have that f(1) = 0
We claim that this implies that ##f(r) = 0 \ \forall \ r \in \mathbb{Z}## ...
'Proof'
We have ##f(1) = 0##
##\Longrightarrow f(2) = f(1) + f(1) = 0 + 0 = 0##
##\Longrightarrow f(3) = f(2) + f(1) = 0 + 0 = 0##
... and so on ...
So for all positive integers ##r##, we have ##f(r) = 0## ... (could have done this formally via mathematical induction)For the negative integers we proceed as follows:
Given that ##f## is a ring homomorphism we have that ##f(-1) = -f(1)## ...
... so ##f(-1) = -f(1) = -0 = 0##
##\Longrightarrow f(-2) = f( (-1) + (-1)) = f(-1) + f(-1) = 0 + 0 = 0##
##\Longrightarrow f(-3) = f( (-2) + (-1)) = f(-2) + f(-1) = 0 + 0 = 0##
and so on ...
... so for all the negative integers ##s = -r## we have ##f(s) = 0##
.. and ...
we also have that, given that ##f## is a ring homomorphism, ##f(0) = 0## So we have for all integers ##r, f(r) = 0##
Case B
For a ring homomorphism ##f \ : \ \mathbb{Z} \rightarrow \mathbb{Z}## we have that f(1) = 1
We claim that this implies that ##f(r) = r \ \forall \ r \in \mathbb{Z}## ...
'Proof'
We have ##f(1) = 1##
##\Longrightarrow f(2) = f(1) + f(1) = 1 + 1 = 2##
##\Longrightarrow f(3) = f(2) + f(1) = 2 + 1 = 3##
... and so on ...So for all positive integers r, we have f(r) = r ... (could have done this formally via mathematical induction)For the negative integers we proceed as follows:
... so ##f(-1) = -f(1) = -1##
##\Longrightarrow f(-2) = f( (-1) + (-1)) = f(-1) + f(-1) = (-1) + (- 1) = -2##
##\Longrightarrow f(-3) = f( (-2) + (-1)) = f(-2) + f(-1) = (-2) + (- 1) = -3##
and so on ...
... so for all the negative integers ##s = -r## we have ##f(s) = s##
... and ...
we also have that, given that f is a ring homomorphism, ##f(0) = 0## So we have for all integers ##r, f(r) = r##Hope that is what was required ...
Peter
Yes, that's fine. You could have also used a general "##n##" and some "##\ldots ##" with the exact same arguments.
Likes Math Amateur
Related to Ring Homomorphisms from Z to Z .... Lovett, Ex. 1, Section 5.
1. What is a ring homomorphism?
A ring homomorphism is a function that preserves the algebraic structure of a ring. It maps elements from one ring to another in a way that respects the ring operations of addition and multiplication.
2. What is the domain and codomain of a ring homomorphism from Z to Z?
The domain of a ring homomorphism from Z to Z is the set of integers (Z) and the codomain is also the set of integers (Z).
3. How is a ring homomorphism different from a group homomorphism?
A ring homomorphism preserves both addition and multiplication, while a group homomorphism only preserves the group operation (usually multiplication). Additionally, a ring homomorphism maps between two rings, while a group homomorphism maps between two groups.
4. What is the kernel of a ring homomorphism from Z to Z?
The kernel of a ring homomorphism from Z to Z is the set of elements in the domain that are mapped to the additive identity (0) in the codomain. In other words, it is the set of elements that are mapped to 0.
5. Can a ring homomorphism from Z to Z be surjective but not injective?
Yes, a ring homomorphism from Z to Z can be surjective (onto) but not injective (one-to-one). This means that there are elements in the codomain that have multiple preimages in the domain, but not every element in the codomain has a unique preimage.
  • Linear and Abstract Algebra
