tze liu
- 57
Recently i watch a video about Thermal Bremsstrahlung.
and i don't understand the explanation that they use a ring instead of disk in 6:02 to 7:06.
(1)how did he divided the set of electrons up into in
two sets of velocities that are all in
the same direction and sum
over all of the different velocity directions?
(2)why is this related to the reason he uses a ring instead of a shell?
the another question is even there are some electrons(ne) stayed inside the area between b and b+db
this doesn't mean those electrons are in the distance of closest appraoch,and this only means some of them pass through this area(may be they can appraoch the nucleus which has radius r < b),and i get stuck why this logic works here.I am not good at understand those basic concept about thermal free-free emission.
thank you very much!
6:02
they might wonder why we've chosen to
06:03
examine a ring here instead of a shell
06:05
and the answer is a little hard to
06:07
visualize but we'll give it a shot we're
06:09
starting with a number density of
06:10
electrons we're asking how many of them
06:13
passed by this atom at a distance B if
06:16
we selected only the electrons out of
06:19
this cloud that were moving say from the
06:21
left side of the page to the right side
06:22
of the page then for that fixed
06:24
direction we would only see a mission
06:26
from these electrons in one ring as it
06:30
passes by the nucleus similarly if we
06:33
start if we selected only the electrons
06:35
that were starting at the bottom of the
06:36
page and moving up towards the top those
06:38
electrons also would only emit towards
06:41
as they pass through this ring so if you
06:44
divide your set of electrons up into in
06:47
06:49
the same direction so all the electrons
06:50
that are going in a similar direction
06:52
each one of those is only emitting over
06:55
this region that that's a ring so when
06:58
we sum over all of the different
06:59
velocity directions that these electrons
07:01
are traveling in multiplied by the
07:04
factor of the differential ring when we
07:07
add those all together it's equal to the
07:09
number density of the electrons times
07:11
the same ring size for all of those
07:13
different velocity directions so that's
07:14
why we end up with only a factor of a
07:16
ring and not a shell
6:02
06:03
06:05
06:07
06:09
06:10
06:13
06:16
06:19
06:21
06:22
06:24
06:26
06:30
06:33
06:35
06:36
06:38
06:41
06:44
06:47
06:49
06:50
06:52
06:55
06:58
06:59
07:01
07:04
07:07
07:09
07:11
07:13
07:14
07:16
