MHB Rings of Fractions .... Lovett, Section 6.2, Proposition 6.2.6 .... ....
Math Amateur
MHB
I am reading Stephen Lovett's book, "Abstract Algebra: Structures and Applications" and am currently focused on Section 6.2: Rings of Fractions ...
I need some help with the proof of Proposition 6.2.6 ... ... ...
Proposition 6.2.6 and its proof read as follows:
View attachment 6466In the above proof by Lovett we read the following:
" ... ... By Lemma 6.2.5, the function $$\phi$$ is injective, so by the First Isomorphism Theorem, $$R$$ is isomorphic to $$\text{Im } \phi$$. ... ... "
*** NOTE *** The function $$\phi$$ is defined in Lemma 6.2.5 which I have provided below ... ..
My questions are as follows:Question 1
I am unsure of exactly how the First Isomorphism Theorem establishes that $$R$$ is isomorphic to $$\text{Im } \phi$$.
Can someone please show me, rigorously and formally, how the First Isomorphism Theorem applies in this case ... Question 2
I am puzzled as to why the First Isomorphism Theorem is needed in the first place as $$\phi$$ is an injection by Lemma 6.2.5 ... and further ... obviously the map of $$R$$ to $$\text{Im } \phi$$ is onto, that is a surjection ... so $$R$$ is isomorphic to $$\text{Im } \phi$$ ... BUT ... why is Lovett referring to the First Isomorphism Theorem ... I must be missing something ... hope someone can clarify this issue ...Peter===================================================
In the above, Lovett refers to Lemma 6.2.5 and the First Isomorphism Theorem ... so I am providing copies of both ...Lemma 6.2.5 reads as follows:
https://www.physicsforums.com/attachments/6467
The First Isomorphism Theorem reads as follows:
https://www.physicsforums.com/attachments/6468
Peter said:
Question 1
Since $\phi$ is injective, its kernel is trivial, and hence $R \approx \text{Im } \phi$ by the first isomorphism theorem. Perhaps you're forgetting that $R/{0} \approx R$.
Peter said:
Question 2
Having a surjection from one ring onto another does not imply that the rings are isomorphic. The image of $\phi$ is a subring of $D^{-1}R$, and is also isomorphic to $R$ by the first isomorphism theorem. So the first conclusion of Proposition 6.2.6 holds.
Thanks Euge ...
Appreciate your helpPeter
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
