MHB Rings of Fractions .... Lovett, Section 6.2 ....
In Stephen Lovett's "Abstract Algebra: Structures and Applications," Section 6.2 discusses the construction of rings of fractions, specifically addressing the isomorphism between the ring of fractions formed with positive integers and the rational numbers. The discussion clarifies that any rational number can be expressed as a fraction with a positive denominator, allowing for a straightforward mapping. This mapping, referred to as the "identity" map, establishes a one-to-one and onto homomorphism from the ring of fractions with positive denominators to the rational numbers. The participants emphasize that multiplying both the numerator and denominator by -1 can adjust negative denominators to positive ones. Understanding this isomorphism is crucial for grasping the properties of rings of fractions in abstract algebra.
Math Amateur
MHB
I am reading Stephen Lovett's book, "Abstract Algebra: Structures and Applications" and am currently focused on Section 6.2: Rings of Fractions ...
I need some help with some remarks following Definition 6.2.4 ... ... ...
The remarks following Definition 6.2.4 reads as follows:https://www.physicsforums.com/attachments/6461In the above text from Lovett we read the following:
" ... ... it is not hard to show that if we had taken $$D = { \mathbb{Z} }^{ \gt 0 }$$ we would get a ring of fractions that is that is isomorphic to $$\mathbb{Q}$$. ... ... "Can someone please help me to understand this statement ... how is such an isomorphism possible ... in particular, how does one achieve a one-to-one and onto homomorphism from the positive integers to the negative elements of $$\mathbb{Q}$$ as well as the positive elements ...
Hope someone can help ... ...
Peter=================================================
To enable readers to understand Lovett's approach to the rings of fraction construction, I am providing Lovett Section 6.2 up to an including the remarks following Definition 6.2.4 ... as follows:https://www.physicsforums.com/attachments/6462
https://www.physicsforums.com/attachments/6463
https://www.physicsforums.com/attachments/6464
The simple reason is that any element $q\in Q$ can be realized as $q={a\over b}$ with $b>0$. If a denominator is negative, just multiply numerator and denominator by -1.
Formally, let $Q_1$ be the ring constructed with denominators positive. It's then easy to verify that the "identity" map from $Q_1$ to $Q$ is an isomorphism.
Thanks johng ... appreciate the help ...
Peter
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
