Rise of Liquid from Horizontal Acceleration
The discussion focuses on the relationship between vertical and horizontal acceleration in a liquid-filled container, referencing Halliday & Resnick's Physics. A scenario is proposed involving an inverted L-shaped rod and a mass on a string to explore whether the string would hang vertically under acceleration. The concept of plumb bobs being perpendicular to liquid surfaces is examined, questioning the observations of a moving observer. The conversation hints at the complexities of understanding acceleration in a fluid context. Overall, the thread seeks clarification on the dynamics of acceleration and its effects on liquid behavior.
Ben2
"Consider the horizontal acceleration of a mass of liquid in an open container. Acceleration of this kind causes the liquid surface to drop at the front of the tank and to rise at the rear. Show that the liquid surface slopes at an angle \theta with the horizontal, where tan \theta = a/g, a being the horizontal acceleration."
p = p_0 + \rho gh
The only way I get this is to make a the vertical acceleration at the bottom corner and g the horizontal acceleration there. This is from Halliday & Resnick's Physics. I've been unable to find anything there or in REA's Physics Problem Solver. Thanks for any hints submitted.
Suppose I attached an inverted L-shaped rod to the side of the accelerated container and suspended a string with a mass tied at the other end. Would the string hang vertically? If not, why not? Now consider the well known fact that masses at the ends of strings, a.k.a. plumb bobs are perpendicular to free surfaces of liquids. Would an observer moving as one with the liquid and the plumb bob see anything unusual? Do you see where this is going? If not, follow the link that was posted above just before I posted this.
Likes Lnewqban and MatinSAR
Consider the case a=0.
Are you sure you are taking ##\theta## as the angle to the horizontal?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
