fluidistic
- 264
Using my classnotes and what the professor did, it is not clear to me as how I must tackle the following problem.
I'm given the potential ##V(x)= V_0 \left ( \frac{x^2}{2} -K \right ) e^{-a x^2}## where a>0.
I must estimate via Ritz method the ground state energy. I must use a trial wave-function ##\Psi \propto e^{-\alpha x^2}##.
##E=\frac{\langle \Psi , \hat H \Psi \rangle }{||\Psi||^2}##.
I know that the energy value I should get is greater than the ground state energy, because the Ritz method gives an upper bound of the ground state energy.
First confusion: in the formula ##E=\frac{\langle \Psi , \hat H \Psi \rangle }{||\Psi||}##, is psi a linear combination of pure states psi's. i.e. ##\Psi = \sum _{n=0} ^{\infty} c_n \psi## (which I believe so) or is it just ##\Psi =ce^{-\alpha x^2}##? To get us started on the exercise my professor used the second case, but I don't understand why.
So I've used the way my professor started us. I splitted the Hamiltonian operator into kinetic and potential energies operators. Yielding ##\langle \Psi , V(\hat x ) \Psi \rangle =c^2V_0 \sqrt \pi \left [ \frac{1}{2(2\alpha +a)^{3/2}} -\frac{K}{(2\alpha +a )^{1/2}} \right ]## (I think the units make sense). While ##\langle \Psi , \frac{\hat{\vec p }}{2m} \Psi \rangle =\frac{c^2\hbar ^2 \sqrt{\pi \alpha}}{2^{3/2}m}##.
I found the constant c by normalizing: ##\langle \Psi , \Psi \rangle =1 \Rightarrow c^2= \sqrt{\frac{2\alpha}{\pi}}##.
So that finally ##\langle \Psi , \hat H \Psi \rangle = \sqrt{\frac{2\alpha}{\pi}} V_0 \sqrt \pi \left [ \frac{1}{2(2\alpha +a)^{3/2}} -\frac{K}{(2\alpha +a)^{1/2}} \right ] + \sqrt{\frac{2\alpha}{\pi}} \frac{\hbar ^2 \sqrt{\pi \alpha}}{2^{3/2}m}##. I know I can simplify slighlty this last expression but my doubt is too big to continue. Why am I working on a single psi that is not a linear combinations of others?!
To continue, I should derivate that expression with respect to alpha and equate to 0? As if I was looking for a minimum in ##E(\alpha)## so I would obtain the value for alpha that minimize E. Is this correct?
Edit: I've derived the expression E(alpha) with respect to alpha and equated to 0 but it doesn't seem an easy job to isolate alpha.
