SnowLurk
- 2
Is there anybody that knows anything about fall factors? I'm a climber trying to learn about the consequences of overloading my gear. Below is a couple of links. One explains what a fall factor is and the other is a calculator that enables you to determine the fall factor and the shock in kilo Newtons (kN). I have played around with the formula and it appears to be flawed when I enter lower values. In the example below, I use 1 foot fall and it would seem impossible that the shock would be 2,000 lbs. Can anybody else confirm this? Please play with it and see for yourself. I occosionally using aid climbing gear that is rated as low as 2 kN. I would like to know how far I can fall on such a small gear item without pushing the limits. Life or death here. LOL
http://www.southeastclimbing.com/faq/faq_fall_factor.htm
http://shockforce.com/
For example if I used variables:
weight = 170 lbs.
Lenght of rope = 1 foot
Distance from last anchor = 1 foot
Type of rope = Dynamic
The output is ??
Fall Factor = 2 severe
Shock= 8.67 kN or 1949 lbs of force (224.81 lbs x 8.67 kN)
weight = 170 lbs.
The output is ??
