Rocker Output-Two Positions with Angular Displacement
In summary, the conversation discusses the process of designing a fourbar Grashof crank-rocker mechanism to achieve 45° of rocker rotation with equal time forward and back. The solution involves drawing the output link in extreme positions, selecting a point and drawing a circle to determine the length of the coupler, and checking the Grashof condition. The website provided by Bobbywhy may provide further explanation on understanding and designing for equal times in the mechanism.
mech-eng
828
This is a example from Robert L. Norton's books on machinery: "Design a fourbar Grashof crank-rocker to give 45° of rocker rotation with equal time forward and back, from a constant speed motor input.
Solution
1)Draw the output link O4B in both extreme positions, B1 and B2 in any convenient location, such that desired angle of motion O4 is subtended
2)Draw the chord B1B2 and extend it in either direction.
3)Select a convenient point O2 on line B1B2 extended.
4)Bisect line segment B1B2, and draw a circle of that radius about O2
5)Label two intersection of the circle and B1B2 extended, A1
and A2
6)Measure the length of the coupler as A1 to B1 or A2 to B2
7)Measure ground length 1, crank length 2, and rocker length 4.
8)Find the Grashof condition. If non-Grashof, redo steps 3 to 8 with O2 farther from O4
9)make a model of the linkage and check its function and transmission angles.
Here is what the mechanism seems
I understand the steps but I can't understand by what step does the mechanism have equal time forward back and forth and how can we understand this mechanism has equal time forward and back. Is there any criteria or formula which show mechanims' back and forth time.
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
I am fairly certain that example 5-1 in the below website explains how to design and to understand the equal times (Grashof condition). Hope this helps:
http://facultad.bayamon.inter.edu/elay/mecn4110/Analytical%20Linkage%20Synthesis.pdf
Cheers, Bobbywhy
Likes 1 person
Related to Rocker Output-Two Positions with Angular Displacement
1. What is a Rocker Output-Two Positions with Angular Displacement?
A Rocker Output-Two Positions with Angular Displacement is a mechanical system that allows for two different positions of movement, typically back and forth, with a specific angular displacement or rotation. This type of output is commonly used in various machines and devices, such as engines and pumps.
2. How does a Rocker Output-Two Positions with Angular Displacement work?
This type of output typically consists of a rocker arm or lever, which is attached to a pivot point and can rotate about this point. As the rocker arm moves, it causes the attached mechanism to move in a specific angular displacement, allowing for two different positions of movement.
3. What are the advantages of using a Rocker Output-Two Positions with Angular Displacement?
One advantage is that it allows for precise and controlled movement, as the angular displacement can be adjusted and controlled. It also requires less space compared to other types of outputs, making it useful in smaller machines or devices.
4. What are some applications of a Rocker Output-Two Positions with Angular Displacement?
This type of output can be found in various machines and devices, such as internal combustion engines, pumps, and power tools. It can also be used in manufacturing and engineering processes, such as in assembly lines or robotics.
5. How is a Rocker Output-Two Positions with Angular Displacement different from other types of outputs?
A Rocker Output-Two Positions with Angular Displacement is different from other types of outputs, such as linear or rotary outputs, as it allows for two different positions of movement with a specific angular displacement. This type of output is also more compact and can be used in applications where space is limited.
25K
9K
