Rocket in space travels between two stars
In summary: A space rocket travels between two stars separated by 10 light years. Observers on satellites orbiting the stars record a duration of 12 years for the journey.My impression from this statement is that there are two stars and the rocket travels from one star to the other. However, in that case I have difficulty interpreting the observer recordings. What do they represent ?
henrco
47
Hi,
Could I please get some guidance on if my approach and solution are correct here.
I feel I'm on the right track. But even though the answer to part b) feels right, it would be helpful to get advice.
a) What duration is recorded on the rocket’s clocks.
b) What is the separation of the stars in the rocket’s frame of reference? Explain your reasoning.
v = d/t
ε = √1 - v^2/c^2
Calculate the velocity of the space rocket.
Distance and time in light years and years, convert to meters and seconds.
v = d/t
d = 10 light years (1 light year = 9.46 x 10^15 m)
t = 12 years (1 year = 3.156 x 10^7 sec)
v = 10 (9.46 x 10^15 m) / 12(3.156 x 10^7) = 2.50 x 10^8 m/s
c (speed of light) = 2.998 x 10^8
Calculate ε = √1- (2.50x10^8)^2 / (2.998x10^8)^2 = 0.55
Calculate time recorded on internal ships clocks. = 0.55 x 12 = 6.62 years
Answer a) 6.62 years
Part b)
d = t.v = (6.62)(3.156x10^7) x (2.5x10^8) = 5.22318 x 10^16 m
d = 8 light years
Answer b) 8 light years
henrco said:
Hi,
v = d/t
ε = √1 - v^2/c^2
v = d/t
Part b)
d = 8 light years
Converting to m/s is horrible! Why not stick with light years, years and velocity as a fraction of ##c##?
The answer to a) looks correct, but b) is wrong. You can see this immediatley by noting that it cannot take 6.62 years for the star to travel 8 light years relative to the rocket.
Likes henrco
Thanks for your reply.
However I've been looking at part b) which you said is wrong and I can't understand how to derive the correct solution.
If the duration on the rockets clocks is 6.62 years, answer to part a. The I would expect the distance from the rockets
frame of reference to be shorter than 10 light years (the external reference frame). Is my reasoning right or wrong?
If I right or wrong I'd appreciate a push in the right direction as I'm stuck on this.
If the duration on the rockets clocks is 6.62 years, answer to part a. The I would expect the distance from the rocket's
Indeed, the distance that the star travels in the rockets frame must be less than 10 light-years.
How does PeroK know that 8 light-years is incorrect?
How far does light travel in 6.62 years?
The relative speed of the star to the rocket ship is less than the speed of light, so the star travels an even shorter distance in 6.62 years.​
My impression from this statement is that there are two stars and the rocket travels from one star to the other. However, in that case I have difficulty interpreting the observer recordings. What do they represent ? The time between such an observer seeing the rocket at star 1 and seeing the rocket at star 2 I would presume ?
Thanks for your reply SammyS but the 'penny' hasn't dropped for me yet.
To answer your question, light would travel 6.62 light years in 6.62 years.
However the speed of of the rocket is 83.39% speed of light. So I'd expect the distance to be larger than 6.62 light years but certainly less than 10.
However you've indicated that the distance should be even shorter than 6.62 light years.
I don't understand how this could be, could you please explain.
The speed of light is ##\displaystyle \ c=1\frac{\mathtt{light\ year}}{\mathtt{year}} \ .\ ##\ Right?
So, in 6.62 years, light travels 6.62 light-years. The rocket is slower than the speed of light, so the distance it travels is less than 6.62 light-years.
Likes henrco
Thank you for this. Clearly my brain decided not to work earlier...
Since the rocket travels at 83.39% of the speed of light, or 83.39c
Then the distance traveled will be 6.62 x 83.39/100 = 5.52 light years.
Related to Rocket in space travels between two stars
1. How long does it take for a rocket to travel between two stars?
The time it takes for a rocket to travel between two stars depends on several factors, such as the distance between the stars, the speed of the rocket, and the type of propulsion system used. In general, it can take anywhere from a few years to several decades for a rocket to reach another star.
2. How does a rocket navigate in space between two stars?
Rockets traveling between two stars use a combination of navigational instruments and guidance systems to determine their position and trajectory. These may include star trackers, gyroscopes, and computer programs that calculate the optimal path to the destination star.
3. Can a rocket travel faster than the speed of light between two stars?
According to our current understanding of physics, it is not possible for any object, including a rocket, to travel faster than the speed of light. Therefore, a rocket traveling between two stars would have to abide by the speed of light limit, which is approximately 186,000 miles per second.
4. Is it possible for humans to survive a journey on a rocket between two stars?
At the moment, it is not feasible for humans to survive a journey on a rocket between two stars. The distance and duration of such a journey would require advanced technology and resources that are not currently available. However, scientists are researching and developing potential methods for long-term space travel for humans.
5. How do rockets refuel or resupply during a journey between two stars?
Currently, there is no established method for refueling or resupplying a rocket during a journey between two stars. This is a significant challenge for long-distance space travel, and scientists are exploring various possibilities, such as using resources from other celestial bodies or developing more efficient propulsion systems.
