Rocket momentum through a cloud of particles
In summary: So they have a momenta on the y-axis before the collision and after the collision, but the net momentum is zero.
EmanueleFWM
A cylindrical rocket of diameter 2R and mass M is coasting through empty space with speed v0 when it encounters an interstellar cloud. The number density of particles in the cloud is N particles/m^3. Each particle has mass m << M, and they are initially at rest.
Assume each cloud particle bounces off the rocket elastically, and that the collisions are so frequent they can be treated as continuous. Prove that the retarding force has the form bv^2, and determine b. Assume the front cone of the rocket subtends angle alpha = pi/2.
The solutions textbook is saying that every particle that hits the rocket has a momentum mv on the horizontal axis, and none after the collision since they get reflected straight up, and from there you can easily prove that the retarding force is bv^2.
Shouldn't the momentum of the particles on the x-axis before the collision be 0 though, since they are at rest, and the one of the rocket MV, and they both stay the same after the collision? The particles get deflected up and down, so they obtain momentum on the y axis, but the momentum of the particles going up cancels that of those going down, so the rocket should not lose any speed on the x-axis neither gain any on the y-axis going through the cloud.
Why is this not the case?
I think the particles bounce upwards in the rocket frame, but at an angle in their original rest frame.
Related to Rocket momentum through a cloud of particles
1. How do particles affect the momentum of a rocket in space?
Particles in space can affect the momentum of a rocket in several ways. If the particles are small enough, they can be deflected by the rocket's surface, causing a change in its momentum. Additionally, if the particles are moving at high speeds, they can collide with the rocket and transfer momentum to it. This can either increase or decrease the rocket's momentum, depending on the direction of the collision.
2. How does the density of particles in a cloud affect a rocket's momentum?
The density of particles in a cloud can greatly affect a rocket's momentum. If the cloud is highly concentrated, the rocket may experience a significant change in momentum as it passes through. However, if the cloud is less dense, the particles may have a smaller impact on the rocket's momentum.
3. Can a rocket change its trajectory by passing through a cloud of particles?
Yes, a rocket can change its trajectory by passing through a cloud of particles. As mentioned before, the particles can collide with the rocket and transfer momentum, causing it to change direction. This can be especially significant if the particles are moving at high speeds.
4. How does the size and speed of particles in a cloud affect a rocket's momentum?
The size and speed of particles in a cloud can have a significant impact on a rocket's momentum. Larger particles have more mass and can transfer more momentum to the rocket, while faster-moving particles can also have a greater effect. Additionally, the direction of the particles' movement can also play a role in determining the change in the rocket's momentum.
5. Can a rocket's momentum be completely cancelled out by passing through a cloud of particles?
It is highly unlikely that a rocket's momentum would be completely cancelled out by passing through a cloud of particles. While the particles can have a significant impact on the rocket's momentum, the rocket's own propulsion system and the fact that it is moving at high speeds in space would likely prevent it from coming to a complete stop.
  • Astronomy and Astrophysics
