etotheipi
- Homework Statement
- The rocket, cross sectional area A and mass M, travels through a cloud of dust of density p. Determine the distance the rocket travels until its velocity is half of its initial velocity.
- Relevant Equations
- CLM
The first way to solve this is to just say, by conservation of momentum, that [itex]M_{0}v_{0}=(M_{0}+Apx)\frac{v_0}{2}[/itex] where [itex]Apx[/itex] is the mass of dust the rocket comes into contact with in a distance [itex]x[/itex].
For the second method, by considering the change of momentum of the dust in 1 second, we know the force applied to the rocket is [itex]-Apv^{2}[/itex]. So if we write down the Newton's second law relation, we get $$-Apv^{2} = (M_{0}+Apx) v \frac{dv}{dx}$$ which when solved does happen to give the same answer as in the first method. However, I thought Newton's second law is only applicable to closed systems of constant mass; so how is this equation giving the same answer?
Is it just a coincidence that method 2 works in this case, i.e. do we actually need to use the variable-mass equation of motion to do it properly?
