dawozel
- 17
Interstellar Spaceship
An interstellar spaceship with initial mass Mo is at rest at the edge of a small, spherical nebula (gas cloud). At t= 0, the engines begin to fire, ejecting gas out the back at constant speed u relative to the rocket. The mass of the rocket decreases at a constant rate: dm/dt= -β, where β is a positive constant. As the spaceship accelerates along a diameter of the nebula, the only external force it experiences is a frictional resistance
proportional to its velocity: f = -kv,where k is a positive constant.
a) use change in momentum to find an expression for dv/dt
in the nebula as a function of time t, velocity v, and constants.
DO NOT JUST STATE A RESULT!
b) While the spaceship is in the nebula, find, in terms of time t
and constants: i. An expression for v(t), the speed of the spaceship.
ii. An expression for x(t), the distance the rocket has traveled.
NOTE Use the initial conditions to remove undetermined
constants.
none I guess, probably use conservation of momentum
so we started with [tex] dm/dt = -β [/tex]
you then turn it into a separable differential equation and you get
[tex] m= -βt +Mo [/tex]
we also know
[tex] f = -kv = mdv/dt [/tex]
now i plugged in for mass
[tex] f = -kv = mdv/dt = (-βt +Mo)dv/dt [/tex]
and finally you get
[tex] dv/dt= -kv/(-βt +Mo) [/tex]
now this may be right but it does not use conservation of momentum to solve, I was hoping you could help me here
