TaylorLL
- 8
Consider a rocket subject to a linear resistive force, $$f = -bv$$, but no other external forces. Use Equation (3.29) in Problem 3.11 to show that if the rocket starts from rest and ejects mass at a constant rate $$k = -\dot{m}$$, then its speed is given by:
$$v = \frac{k}{b}v_{ex}\left[1-\left(\frac{m}{m_{o}}\right)^{b/k}\right]$$
Equation (3.29) $$m\dot{v} = -\dot{m}v_{ex} + F^{ext}$$
[/B]
So I had no issues solving this equation when I used the chain rule and took time out of the equation. Basically, since $$\dot{m} = -k$$, we can plug that into equation 3.29, and then we can find through chain rule that $$\dot{v} = \frac{dv}{dm}\frac{dm}{dt} = -k\frac{dv}{dm}$$. This leads to the expected answer. However, it should also work by finding an equation for mass as a function of time and integrating with respect to time. This is where I'm having issues.
$$m(t) = m_{o} - kt$$
$$\left(m_{o}-kt\right)\frac{dv}{dt} = kv_{ex} - bv$$
$$\int_{0}^{t}\frac{dt'}{m_{o}-kt'} = \int_{0}^{v}\frac{dv'}{kv_{ex} - bv'}$$
When I go through this integral, I almost get the solution with the exception of a flipped exponential term.
$$v = \frac{k}{b}v_{ex}\left[1-\left(\frac{m}{m_{o}}\right)^{k/b}\right]$$
I would appreciate any help, thanks!
