Rocket Thrust Balancing Gravity
In summary, the rocket can only hover for a limited amount of time if it can burn only a mass of fuel equal to lambda.
Piamedes
41
A rocket (initial mass m0) needs to use its engines ot hover stationary, just above the ground. If it can afford to burn no more than a mass (lamda)m0 of its fuel, for how long can it hover? If the exhaust velocity is 3000 m/s and lambda is 10% how long can the rocket hover?
Thrust = [tex] v_{ex} \frac{dm}{dt} [/tex]
[tex] v_{ex} [/tex] is the exhaust velocity
So starting off with the basic sum of forces equals zero:
[tex] \dot{m}v_{ex} = mg [/tex]
[tex] \frac{dm}{dt} = \frac{mg}{v_{ex}} [/tex]
[tex] \frac{dm}{m} = \frac{g dt}{v_{ex}} [/tex]
[tex] \frac{g}{v_{ex}} \int_{0}^{t} dt = \int_{m_{0}}^{m_{0} - \lambda m_{0}} \frac{dm}{m}[/tex]
[tex] \frac{g}{v_{ex}} t = ln(m) ]_{m_{0}}^{m_{0} - \lambda m_{0}} [/tex]
[tex] \frac{g}{v_{ex}} t = ln [m_{0} - \lambda m_{0}] - ln [m_{0}] [/tex]
[tex] \frac{g}{v_{ex}} t = ln [\frac{m_{0} - \lambda m_{0}}{m_{0}}] [/tex]
[tex] \frac{g}{v_{ex}} t = ln [ 1 - \lambda] [/tex]
[tex] t = \frac{v_{ex}}{g} ln [ 1 - \lambda] [/tex]
And here is where I encounter an issue. Since lambda will always be positive, regardless of how much fuel the rocket can expend this equation will give a negative time. Does anyone see where I went wrong with the calculations, or are my original assumptions wrong?
Thanks for any and all help
The thrust equation just gives magnitude. Note that dm/dt should be a negative number since mass is decreasing.
So if I carry along the negative associated with the decreasing mass, then the last few steps would be:
[tex] (-) t = \frac{v_{ex}}{g} ln [ 1 - \lambda] [/tex]
[tex] t = - \frac{v_{ex}}{g} ln [ 1 - \lambda] [/tex]
[tex] t = \frac{v_{ex}}{g} ln [ (1 - \lambda)^(-1)] [/tex]
[tex] t = \frac{v_{ex}}{g} ln [ \frac{1}{1 - \lambda}] [/tex]
And that would give a positive value for time. This equation makes sense, but is it a proper solution?
That's correct.
Thanks!
Related to Rocket Thrust Balancing Gravity
1. What is rocket thrust balancing gravity?
Rocket thrust balancing gravity is the concept of using the force of a rocket's thrust to overcome the force of gravity in order to achieve lift-off and propel the rocket into space.
2. How does rocket thrust balance gravity?
Rocket thrust balances gravity by producing a force that is greater than the force of gravity acting on the rocket. This allows the rocket to overcome the downward force of gravity and achieve lift-off.
3. Why is rocket thrust balancing gravity important?
Rocket thrust balancing gravity is important because it is essential for launching rockets into space. Without this concept, rockets would not be able to generate enough force to overcome the force of gravity and reach the necessary speed and altitude for space travel.
4. What factors affect rocket thrust balancing gravity?
The main factors that affect rocket thrust balancing gravity include the weight and size of the rocket, the amount of fuel and the efficiency of the rocket's engines. Aerodynamics, air resistance, and the gravitational pull of other celestial bodies can also play a role in the balance of forces.
5. How is rocket thrust balancing gravity calculated?
The calculation for rocket thrust balancing gravity involves using Newton's second law of motion, which states that the force of an object is equal to its mass multiplied by its acceleration. In this case, the force of the rocket's thrust is compared to the force of gravity acting on the rocket, and adjustments are made to ensure that the thrust is greater than the force of gravity.
