Rod colliding with the ground (Special relativity question)
The discussion revolves around the collision of a rod with the ground as observed from different frames of reference in the context of special relativity. The participants analyze the timing and spatial relationships of the rod's ends hitting the ground, noting that the events are not simultaneous in the particle's frame due to relativistic effects. They derive the angle the rod makes with the horizontal upon collision, emphasizing the importance of considering the horizontal distance between the rod's ends in the primed frame. The conversation also touches on the contraction of the rod in the ground frame and the implications of elastic collisions. The final conclusions suggest a complex interplay of velocities and relativistic factors, leading to a deeper understanding of the rod's behavior during the collision.
LCSphysicist
Ok, so basically: There is a frase with a particle moving horizontally with velocity v and a rod parallel to the ground, with rest length L, falling with speed u vertical constant. The rod bounces off on the ground. Describe what happens in the particle frame and find the angle the rod makes with the horizontal when it collides in this frame.
So i tried this:
The event A, the left corner of the rod hits the ground.
The event B, the right corner hits the ground.
In the ground frame, Ta=Tb=0. ##\Delta x = L/\gamma_u##
So, LT to the particle frame, we have $$|\Delta t'| = |\gamma_v \beta_v \Delta x|, |\Delta x'| = | \gamma_v \Delta x|$$
That is, the rod don't hit the ground simultaneously, the right corner will hit it with a difference of time ##|\Delta t'|##
So, when the left corner touches the ground, the time the right corner is elevated ##y' = u \Delta t' = u' \gamma_v \beta_v \Delta x##
Since u is perpendicular to v, u', the vertical velocity of the rod in the particle frame, is ##u' = u/\gamma_v##.
##y' = u '\Delta t' = (u/\gamma_v) \gamma_v \beta_v \Delta x = u\beta_v \Delta x ##
##tan\theta' = y'/\Delta x' = u\beta_v \Delta x/\Delta x' = u\beta_v / \gamma_v##
Ignore the units, i put c=1.
This is just wrong. Could you help me to solve the question?
According to IFRs, the rod is horizontal, right up or left up in touching the ground. I do not find anything wrong with it.
In the ground frame, the rod is moving perpendicularly to its length. Should the rod be contracted in the ground frame?
Ok. In the middle expression, ##u## should have a prime. But you have it correct in the final expression.
Ok
Here, ##\Delta x'## should be the (simultaneous) horizontal distance between the left and right ends of the rod as seen in the primed frame. This is not the same as the horizontal distance between events A and B as seen in the primed frame. In the primed frame, A and B do not occur simultaneously. So, the rod moves horizontally during the time between the events in the primed frame.
TSny said:
In the ground frame, the rod is moving perpendicularly to its length. Should the rod be contracted in the ground frame?Ok. In the middle expression, ##u## should have a prime. But you have it correct in the final expression.OkHere, ##\Delta x'## should be the (simultaneous) horizontal distance between the left and right ends of the rod as seen in the primed frame. This is not the same as the horizontal distance between events A and B as seen in the primed frame. In the primed frame, A and B do not occur simultaneously. So, the rod moves horizontally during the time between the events in the primed frame.
Thank you by the reply. So considering the last paragraph, i think we could say that:
The horizontal distance between the ends of the rod will be equal to $$\Delta S = \Delta X' - v\Delta t' = \gamma_v \Delta X - v \gamma_v \beta_v \Delta X$$
So that $$tan = u\beta_v \Delta X/(\Delta X (\gamma_v - v \gamma_v \beta_v)) = u v / (\gamma_v - v^2 \gamma_v ) = uv \gamma_v$$
So, is that right? I was expecting something involving ##gamma_u## too. At least to me, it is quite amazing it does not appear here.
That looks right.
It's interesting to consider the shape of the rod in the primed frame at times between the two events B and A for the case where the rod bounces elastically off the ground in the ground frame.
Likes LCSphysicist
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
