Role of entanglement in general purpose quantum computing
In summary, entanglement is a valuable resource for quantum computers, but it is not the only one and there are many things that need to be worked out before they can be effectively used.
raphampm
I've been doing a course on Quantum Computing and I haven't managed to figure out so far how entanglement would be a useful resource on a general purpose quantum computer.
By general purpose quantum computer I mean some theoretical device that could possibly replace current classical computers in the future (if at all likely).
So my question probably boils down to how important a role would entanglement play in the substitution of current classical computers by quantum computers in the future?
Entanglement is what gives quantum computers their enormous potential. Without that, they would be a LOT more trouble than they are worth. The quantum computer can find the solution of a problem with many conditions and constraints in one step. (I really should say "phase" instead of "step" because finding the solution actually takes a few steps ... but ignore that for now.) Suppose you need to find the unique combination of 100 binary inputs that will give a desired result. Entanglement would conceivably allow the solution to be found in one (or a small number) step by a quantum computer with 100 entangled qubits. If there is no shortcut algorithm, a traditional computer might need to start testing all 2100 ≈ 1029 combinations one at a time till it found the solution. Even the fastest traditional computer would need billions of years to solve it.
That is the enormous potential of the quantum computer. The problems with getting them to work and solve something are also enormous.
How are you planning to run Grover's algorithm or Shor's algorithm, or any quantum algorithm for that matter, without some of the qubits being entangled along the way? In that sense it's not so much a resource as an unavoidable necessity.
Entanglement does also have uses as a resource, independent of specific algorithms. A good example is quantum teleportation, which has to burn entanglement to work. I wouldn't be surprised if early quantum computers used teleportation as a scaling mechanism. It might even be better, in terms of the number of errors, to not directly send qubits over a noisy quantum channel and instead send EPR pairs which you then use (in combination with the classical internet) for teleportation. Since EPR pairs are interchangeable, you could then use error detection instead of error correction over the quantum channel.
Related to Role of entanglement in general purpose quantum computing
1. What is entanglement?
Entanglement is a phenomenon in quantum mechanics where two or more particles become connected in such a way that the state of one particle affects the state of the other, even when they are separated by a large distance. This connection is known as quantum entanglement and is one of the key principles of quantum computing.
2. How does entanglement play a role in general purpose quantum computing?
Entanglement plays a crucial role in general purpose quantum computing as it allows for the creation of quantum states that are not possible in classical computing. This enables quantum computers to perform certain calculations and solve certain problems much faster and more efficiently than classical computers.
3. What are the advantages of using entanglement in quantum computing?
One major advantage of using entanglement in quantum computing is the ability to perform certain calculations and solve certain problems much faster and more efficiently than classical computers. Entanglement also allows for the creation of quantum states that are not possible in classical computing, providing potential for new applications and advances in technology.
4. Are there any challenges in utilizing entanglement for general purpose quantum computing?
Yes, there are several challenges in utilizing entanglement for general purpose quantum computing. One major challenge is maintaining and controlling the entanglement of particles, as it is very fragile and easily disrupted by external influences. Another challenge is scaling up the number of entangled particles, as the complexity and resources needed to control and analyze them increases exponentially.
5. How is entanglement being used in current quantum computing research?
Current research in quantum computing is heavily focused on utilizing entanglement to improve the capabilities and efficiency of quantum computers. This includes developing new algorithms and protocols that take advantage of entanglement, as well as finding ways to overcome challenges in maintaining and scaling up entanglement. Entanglement is also being studied in other fields, such as quantum communication and quantum cryptography, to explore its potential applications beyond computing.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
