Role of Fermi Contact Interaction in J-Coupling
In summary, J coupling in NMR occurs through the Fermi contact interaction, which only occurs with s-electrons due to their nonzero probability density at the nucleus. The magnetic field created by the nucleus is too weak to significantly interact with p or d electrons. The brackets in the formula represent the expectation value, and for orbitals other than s, this value is zero. Two follow-up questions were asked regarding the formula and the expectation value for p electrons.
Steven Hanna
31
I'm having a hard time understanding the mechanism of J coupling in NMR. Why is coupling information only transmitted through bonding electrons with nonzero s-character? For example, why can't coupling information be transmitted through a bond with no s-character, e.g. a retrodative bond between a metal and a ligand? It's been explained to me that J coupling occurs through the Fermi contact interaction, in which the magnetic moment of the nucleus interacts with those of bonding electrons, and that this interaction can only occur with s-electrons since they are the only electrons with nonzero probability density at the nucleus. However, if the nucleus makes a magnetic moment in space, why shouldn't that magnetic moment interact with p or d electrons? I found the following formula for the magnitude of the Fermi contact interaction on Wikipedia.
Do these brackets <> represent an inner product? And if so, is the Fermi contact interaction zero for p electrons because this inner product is somehow zero?
Chemistry news on Phys.org
The magnetic field created by the magnetic moment nucleus is extremely weak, so to first order only the electron density at the nucleus interacts significantly with that magnetic field.
The brackets represent the expectation value. But what is zero is ##\Psi(0)## for orbitals other than s.
Thanks for your quick reply! Two followup questions:
1) Is this formula just an approximation, i.e. could a nuclear magnetic moment weakly interact with that of a p-electron through space?
2) Is the expectation value of this dot product necessarily zero for p electrons?
FAQ: Role of Fermi Contact Interaction in J-Coupling
1. What is Fermi Contact Interaction and how does it contribute to J-Coupling?
Fermi Contact Interaction is a type of magnetic interaction between the nuclei and the surrounding electron cloud in a molecule. It contributes to J-Coupling by causing a shift in the energy levels of the nuclei, resulting in the coupling between different nuclear spins.
2. How does J-Coupling affect the splitting of NMR peaks?
J-Coupling results in the splitting of NMR peaks into multiple smaller peaks, known as multiplets. The number of peaks in a multiplet is determined by the number of neighboring nuclei that have a non-zero coupling with the nucleus in question.
3. Can J-Coupling be used to determine the connectivity between atoms in a molecule?
Yes, J-Coupling can be used in NMR spectroscopy to determine the connectivity between atoms in a molecule. The magnitude and sign of J-Coupling can provide information about the distance and orientation between nuclei, which can be used to determine the connectivity of the molecule.
4. How does the strength of Fermi Contact Interaction affect J-Coupling?
The strength of Fermi Contact Interaction directly affects the magnitude of J-Coupling. The stronger the interaction, the larger the J-Coupling value will be. This means that a larger splitting of NMR peaks will be observed in molecules with stronger Fermi Contact Interaction.
5. Can Fermi Contact Interaction be manipulated to alter J-Coupling values?
Yes, Fermi Contact Interaction can be manipulated through changes in the electron density around the nuclei. This can be achieved through changes in temperature, solvent, or the introduction of paramagnetic ions. These manipulations can result in changes in J-Coupling values, which can be used for studying molecular dynamics and structure.
