MHB Rolling 5 Dice: Probability of At Least 3 Sixes
The probability of rolling at least three sixes with five standard 6-sided dice is calculated by considering the total outcomes of 7776. The initial calculation mistakenly counted successful outcomes as 360, but this figure double-counted scenarios with four or five sixes. The correct approach involves calculating the combinations for exactly three, four, and five sixes, leading to a successful outcome of 276. An alternative method using the complement rule yields a probability of 23/648. The accurate probability reflects the complexities of combinatorial counting in dice rolls.
veronica1999
Five standard 6-sided dice are rolled. What is the probability that at least 3 of them show a six?
I am surprised my answer is wrong.
First the total outcomes are 6x6x6x6x6=7776
Successful outcomes 10x6x6=360
There are 10 ways to choose 3 from 5 and then the remaining 2 can be any number.
360/7776 is not the answer.
The answer is 276/7776.:confused:
Mathematics news on Phys.org
Re: dice problem
You have double-counted the ways in which four or five sixes can occur. What you should do is to count the number of ways in which exactly three sixes can occur (10x5x5), then add the number of ways in which four sixes can occur (5x5), and finally the one way in which five sixes can occur.
Re: dice problem
Oops...
Thanks!:D
Re: dice problem
I would use the complements rule:
$$P(X)=1-\frac{{5 \choose 0}5^5+{5 \choose 1}5^4+{5 \choose 2}5^3}{6^5}=\frac{23}{648}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
