Rolling a ball down an inclined slope. Something's wrong.
In summary, a high school student is trying to find the theoretical time it takes for a glue stick to roll down an inclined plane of 10 degrees, but the calculated time does not match the actual time. They are missing the friction force and need to determine the coefficient of friction between the gluestick and inclined plane through experiments. They also need to consider rotational motion, but it is suggested to use a small point object for experimental purposes. It is recommended to study more and have fun with physics.
Enlightnd
Hi guys,
I'm trying to find the theoretical time it takes for a glue stick to roll down an inclined plane of 10 degrees. We then have to compare it to the practical value, which was 1.09 secs.(Average over 10 repetitions). The glue stick has a mass of 10g. The distance of the inclined plane was 41 cm.
a = g * sin( theta ) for acceleration where theta is 10 degrees.
t = SQRT (2d/a) derived from d = d0 + v0t + (1/2)at2
a = 9.8 * sin(10)
a ≈1.70m/s^2
t = SQRT (2* 41/1.7)
t ≈ 6.95.
6.95 does not equal 1.09 at all, so I'm asking did I use the right formula? If not what are the right formulas. And could someone please provide me with a worked example so I can understand this more clearly.
I'm only a high school student doing this as an independent research project so please don't use advanced language, if you have to can you please explain it as well.
Thank you very much, you help is much appreciated. :D
Here you have only taken into account the translational motion of glue stick.Glue stick is like a small cylinder.It will rotate as well as slide on the inclined plane(given that the inclined plane has friction).
If you don't want to take into account the rotational motion,then also you are missing one thing i.e.friction force(=umgcos(theta)).It acts opposite to motion Hence
a=g (sin(theta)-ucos(theta))..(u=coefficient of friction).
If you take into account rotational motion of object,the equation of accn will be a bit more complex.
The answer which you found will be true only in case of frictionless incline which is not possible in real life.
If any more problems,Hit me up again
Thank you very much for your reply. I see that I'm missing friction. So how would i find out the friction between the gluestick and inclined plane? I didn't really understand the last few sentences when you mentioned the formula's relating to friction and acceleration.
*edit. OK I understand some bits now. I've got theta and cos and sin. So the only thing i need now is (u) providing that I don't take into account slipping and sliding. How would i find out (u) then?
No problem Buddy.Every two pair of objects has a particular value of coefficient of fricition(u) which is determined by experiments.Frictional force =uN (u is the coefficient of friction and N is the normal acting on the object).Just asking,Have you read the chapter Laws of motion?
In case of inclined plane (N=mgcos(theta)).so friction=umgcos(theta).
Two forces act on the body mgsin(theta) and umgcos(theta) which are opposte in direction..
F(net)=mgsin(theta)-umgcos(theta)
m.a(net)=mgsin(theta)-umgcos(theta)
a(net)=gsin(theta)-ugcos(theta)
You can only find it out by doing experiments if you beforehand don't know it..Make you clear that the cylinder does slide here .We have only assumed that the cylinder is not rotating..
Have you read Laws of Motion?IF not,then leave it.
Thank you again for your reply. After searching the internet, it said that the coefficient of Friction (u) regarding plastic on wood, was 0.5 and 0.4. Do i just substitute these values in the formula that you provided me with in your first response? And no I haven't read the chapter Laws of motion, although I am looking forward to doing physics in senior high school. Also, regarding 0.5 and 0.4, which value do i substitute? Thank you very much.
Oh. But the cylinder here is rotating. Does that mean I have to use another formula regarding this project? :((
I really appreciate your experimental approach but you need to study a bit more to do it properly..When the cylinder rotate,the equation of the acceleration are quite complex.So don't bother about it..My suggestion would be to take a small point object and experimentally determine the time taken by it to reach the bottom of inclined plane.
Then calculate the theorotical accn using the equation I provided above and then the theorotical time.There are two values of coefficent of friction for a particular pair.Always take the one with the smaller value.And no need to thank me every time.Have fun and do take Physics.It's aweosme
Are you in Class 10?..
Likes 1 person
One thing Princu failed to point out to you is that you made a mistake with units in your problem. 41 cm is 0.41 meters, so your predicted time to go down the plane should have been 0.695 sec rather than 6.95 seconds.
Chet
Likes 1 person
Chet
So sorry, didn't see that.
Uhmmm, no I'm in Year 9 in a selective high school in Sydney Australia, so maybe class 9? I don't know.
Chet
Thanks for correcting. By the way I did succeeded I pointing out the rest.Ha Ha:wink:
Very well.Go ahead and God bless.I have completed my school education and currently preparing for engineering entrance exams due next year.
Likes 1 person
The problem here is that the potential energy due to gravity is being converted both into kinetic energy of the linear motion, and of the rotational motion since the object is rolling.
There's a way to reduce this down to an "effective mass" for the inertial mass of the system. A solid cylinder which has a moment of inertia of [itex]I=1/2 m r^2[/itex]. The kinetic energy of the cylinder as it rolls is the rotational plus linear K.E.
[tex]T = \frac{1}{2} m V^2 + \frac{1}{2} I \omega ^2 [/tex]
Since as it rolls it rotates so that [itex]V=r \omega[/itex], we get...
[tex]T = 1/2 m V^2 + 1/4 m r^2 * V^2 / r^2 = ... = \frac{1}{2}( 1.5m) V^2=\frac{1}{2} M_{eff}V^2[/tex]
OK so the effective mass [itex]M_{eff}[/itex] is 1.5 times the physical mass... this is because there's more kinetic energy tied up in the rolling cylinder than would be a sliding one. Now this extra effective mass doesn't contribute to the weight, i.e. the force due to gravity so you'll see the acceleration have a factor of mass/effective mass or 2/3 the value you used.
Carrying this factor through to the time you'll get a [itex] \sqrt{3/2} \approx 1.225[/itex] correction factor to the time calculates assuming sliding with no friction. In other words for a given problem a solid cylinder will take about 1.225 times longer to roll down than a frictionless object would to slide.
This assumes the chapstick is a solid cylinder of uniform density.
If we go to the extreme and consider a hollow cylinder rolling down a slope you get an effective mass of 2m and so a time correction of [itex]\sqrt{2}\approx 1.414[/itex]. In the case where all the mass is concentrated at the axis of the cylinder the effective mass is 1 m and the cylinder behaves as a point mass sliding down without friction.
Likes 1 person
Because your cylinder is rotating as it descends, some of the energy goes into spinning it up. So its overall motion is slower. Have you studied rotational motion? Moment of inertia ring a bell?
Uhh, to be completely honest, I have not studied anything you guys have mentioned. So yeh I'm a complete noob in physics. Its only an optional extension in our independent research project.
Then I am afraid you can only do the lower bound estimate that you did (but mind the units as Chet said) and then do the hand-waving argument that "rotation slows it down".
Likes 1 person
Ahaha. Ok then. Thanks anyways.
Jambaugh really gave you the result you need. According to what he presented, the frictional force is equal to ma/2 for a cylinder of uniform density. So, as he said, the time should be about 1.225 times as long. 1.225 x 0.695 = 0.85 sec. This is close to your measured value of 1.09 seconds, and is about the best your theoretical estimate is going to do.
FAQ: Rolling a ball down an inclined slope. Something's wrong.
How does the angle of the slope affect the motion of the rolling ball?
The angle of the slope directly affects the acceleration of the rolling ball. The steeper the slope, the greater the acceleration and the faster the ball will roll down the slope.
Why does the rolling ball slow down or stop before reaching the bottom of the slope?
Friction is the main factor that causes the rolling ball to slow down or stop before reaching the bottom of the slope. As the ball rolls, it rubs against the surface of the slope, creating friction that acts in the opposite direction of the ball's motion.
How do different surfaces of the slope affect the motion of the rolling ball?
The type of surface on the slope can greatly affect the motion of the rolling ball. Rough surfaces will create more friction and slow down the ball, while smooth surfaces will have less friction and allow the ball to roll faster.
What is the relationship between the height of the slope and the distance the ball travels?
The height of the slope and the distance the ball travels are directly proportional. This means that as the height of the slope increases, the distance the ball travels will also increase, given that all other factors (such as the angle and surface of the slope) remain constant.
Why does the ball sometimes roll off to the side instead of straight down the slope?
This could be due to the unevenness of the slope or inconsistencies in the surface. If the slope is not perfectly smooth or has bumps and dips, the ball may roll off to the side instead of straight down. Additionally, if the surface is not level, the ball may also roll off to the side.
