Rolling a pair of dice 20 times
So you should divide each frequency by 20 instead of 36.In summary, the conversation discusses creating a frequency table for the outcome of rolling two dice 20 times. The results are listed and there is a question about why the frequencies do not add up to 100%. It is clarified that the frequencies should be divided by 20 instead of 36 since the dice were only rolled 20 times.
Science4ver
35
I have math experiment where I roll a pair of honest dice 20 times.
The results are:
2,3,4,4,5,5,6,6,6,7,7,7,7,7,9,9,9,10,10,11
write a frequency table of the outcome of the dice roll with respect to size:
2,3,4,5,6,7,8,9,10,11,12
Firstly there must 36 possible outcomes since there two dice with 6 sides.
This gives me a frequency table which looks as follows:
x P(x)
2 1/36
3 1/36
4 2/36
5 2/36
6 3/36
7 5/36
8 0
9 3/36
10 2/36
11 1/36
12 0
Is this correct? By why doesn't the frequencies add up to 100%?? Is it because I only role the dice 20 times?
The results are:
x P(x)
2 1/36
3 1/36
4 2/36
5 2/36
6 3/36
7 5/36
8 0
9 3/36
10 2/36
11 1/36
12 0
Dividing by 36 would be correct if you rolled the dice 36 times---but you didn't.
So I just exchange 36 with 20?
What do YOU think?
Ray Vickson said:
What do YOU think?
yes because I roll the dice 20 times and not 36.
Right!
FAQ: Rolling a pair of dice 20 times
1. How many possible outcomes are there when rolling a pair of dice 20 times?
There are 129,600 possible outcomes when rolling a pair of dice 20 times.
2. What is the probability of rolling a double six in 20 rolls?
The probability of rolling a double six in 20 rolls is approximately 0.0003 or 0.03%.
3. What is the expected value of rolling a pair of dice 20 times?
The expected value of rolling a pair of dice 20 times is 140. This means that if the experiment is repeated many times, the average of the resulting values will converge to 140.
4. Is rolling a pair of dice 20 times considered a random experiment?
Yes, rolling a pair of dice 20 times is considered a random experiment because the outcome of each roll is not dependent on the previous rolls and is determined by chance.
5. How does the probability of rolling a seven change after each roll?
The probability of rolling a seven does not change after each roll. Each roll of the dice is an independent event, so the probability of rolling a seven remains constant at approximately 0.167 or 16.7%.
