Rolling cylinder or slipping cylinder reaches bottom first?
In summary, In the rolling case, the cylinder will reach the bottom first because it has more energy.
vcsharp2003
897
177
Two identical cylinders are released from the top of two identical inclined planes. If one rolls without slipping and the other slips without rolling then which one will reach the bottom first? How will their speeds compare when they reach bottom of incline?
I am not sure if my attempt is correct, since this is a test question and I cannot verify my answer.
Apply Work Energy Theorem to both situations
ΔKE + ΔPE = Worknet
Let θ be the angle of incline with horizontal and h it's height. Let v be the velocity at bottom of incline.
for rolling, since force of friction does no work on rolling cylinder, ∴ Worknet = 0
∴ (0.5 x m x v2 - 0 ) + (0 - mgh) = 0
0.5 x m x v2 = mgh
for sliding, force of friction does work, ∴ Worknet ≠ 0
∴(0.5 x m x v2 - 0 ) + (0 - mgh) = - f x hsinθ
0.5 x m x v2 = mgh - fhsinθ
From above analysis, the velocity at bottom for rolling disk will be greater, which also means the rolling disk will reach bottom first.
For the rolling cylinder, where has the energy come from (or gone to) in order to make it spin? Think about the energy of rotation.
For the sliding cylinder that does not roll, can there be any friction at all?
Likes vcsharp2003
The one that is rolling gains angular momentum, and thus energy of angular motion. You need to include this in your analysis..
Likes vcsharp2003
That is a very nice point. Since cylinder slips, then friction should not be there. Friction is what causes cylinder to roll by supplying the necessary torque. Right?
In that case, the problem becomes simpler. The initial PE of cylinder in rolling case gets divided into final linear KE + final rotational KE, whereas, in sliding case the same PE goes wholly into it's final linear KE, and therefore the sliding case will have a higher velocity at bottom and also reach the bottom first.
Does above reasoning sound right to you?
Likes gneill and TomHart
Yes, that's it.
Perhaps a clarification is needed for OP's benefit that by "the speed of the cylinder" is tacitly meant "the speed of the center of mass". In the case of slipping, all points on the cylinder move at the same speed; in the case of rolling without slipping, some points on the cylinder move faster and some slower than the center of mass while the point of contact moves not at all (otherwise there would be slipping). Nevertheless, the argument in post #4 is valid when one considers that ##PE=\frac{1}{2}m V^2_{CM}## when there is only slipping and ##PE=\frac{1}{2}m V^2_{CM}+ K_{rot.}## when there is rolling without slipping.
Likes vcsharp2003 and gneill
Related to Rolling cylinder or slipping cylinder reaches bottom first?
1. What is the difference between a rolling cylinder and a slipping cylinder?
A rolling cylinder is one that is in motion without any slipping or sliding, while a slipping cylinder is one that is in motion but also experiencing some slipping on its surface.
2. How does the surface of the ground affect the speed at which a cylinder reaches the bottom?
The surface of the ground can have a significant impact on the speed at which a cylinder reaches the bottom. A rough surface can cause more friction and slow down the cylinder, while a smooth surface can reduce friction and allow the cylinder to reach the bottom faster.
3. Is there a difference in the time it takes for a rolling cylinder and a slipping cylinder to reach the bottom?
Yes, there is a difference. A rolling cylinder will reach the bottom faster than a slipping cylinder due to the reduced friction on its surface.
4. What factors can affect the speed at which a cylinder reaches the bottom?
Some factors that can affect the speed of a cylinder reaching the bottom include the surface of the ground, the weight and shape of the cylinder, and the force applied to the cylinder.
5. Can a rolling cylinder and a slipping cylinder reach the bottom at the same time?
No, due to the difference in friction, a rolling cylinder will always reach the bottom before a slipping cylinder.
