Rolling hoop and lagrange multipliers
In summary, to solve for the radial force on the smaller hoop as a function of the angle that it rotates around the cylinder, you need to solve for 5 equations in 3 generalized co-ordinates and 2 Lagrange multipliers.
ehrenfest
2,020
A uniform hoop of mass m and radius r rolls without slipping on a fixed cylinder of radius R. The only external force is that of gravity. If the smaller cylinder starts rolling from rest on top of the bigger cylinder , use the method of lagrange multipliers to find the point at which the hoop falls off the cylinder.
So, it will fall off when the radial force is 0, right? Should I use virtual forces and d'Alemberts principle to do this problem? I want to get the radial force as a function of the angle that the smaller hoop rotates along the cylinder, right?
EDIT: the word smaller in the last sentence should not be there because there is only one hoop
Is it a hoop or a cylinder(?)..seems to change back and forth.
In any case, you've got 2 constraints. Write down their equations in the desired form, extract the coefficients of the derivatives of generalized co-ordinates, and use them in the full form of the Lagrange equations. It looks like you will end up with 5 equations (including the 2 constraint equations) in 3 generalized co-ordinates and 2 Lagrange multipliers. One of these Lagrange multipliers comes with the constraint that the hoop be one the surface of the cylinder. That's the one you care to solve for.
So the 3 generalized coordinates would be the angle that the hoop has rotated, call it theta.
Another would be the angle from the center of the cylinder to the center of mass of the hoop, call it phi.
[tex] T = 1/2 m (r\dot{ \theta})^2 [/tex]
[tex] V = -(R + r) m g sin \phi [/tex]
Are those good generalized coordinates? I am not sure that they are even independent...
Those are two. You need a third, which it appears you have eliminated by how you've written the V term; and you've also eliminated one constraint equation in the process. But the third co-ordinate and this constraint equation are important.
Also, there must be an additional term in T; you've covered rotation about the hoop's axis, but what about the "translational" term a.k.a. rotation about the cylinder's axis?
PS: It looks like you are measuring \phi from the horizontal. It may be easier if you measured it from the vertical (starting position of hoop) instead.
OK. I guess the third is the distance from the hoops center (of mass) to the center of the cylinder, call it d.
Then
[tex] T = 1/2 m (r\dot{ \theta})^2 + 1/2m ((R+d) \dot{ \phi})^2+ 1/2 m (\dot{d})^2 [/tex]
[tex] V = -(R + d) m g \cos \phi [/tex]
with the new definition of phi.
So, I know how to plug that into the EL equation and get the three equations of motion. However, I am not sure how to get the other two equation that you referred for the restraints and I am not sure where the Lagrange multipliers will come in...
You will find this in any standard classical mechanics text, such as Goldstein.
First, Identify the two constraints:
1. Hoop is rolling without slipping
2. Hoop is touching the surface of the cylinder
Both these constraints can be written in the form : [itex]\sum_j a_{ij} \delta q_j = 0 [/itex]
Example, for 2: [itex]\delta d = 0 [/itex]
Now, for the virtual work done by the constraint forces (in this case friction, and the normal reaction) to be zero, we can write these forces as [itex]f_j = \sum _i \lambda_i a_{ij} [/itex]. Finally, all you need to do is use stick these forces in the (RHS of the) 3 EL EoMs that you have.
So, the other constraint is [tex] \dot{\theta} = \dot{\phi} [/tex] (2), right?
So, I guess if we write that in terms of virtual displacements, it would be
[tex] \delta \theta = \delta \phi [/tex] (1)
right?
But, d'Alembert's principle is something I am struggling with, can you help me figure out rigorously how you go from (2) to (1)?
I have the Goldstein book and indeed this is a question from it.
Actually, that should be [tex]d \dot{\phi} = r \dot{\theta}[/tex]. Make sure that's clear.
Also, in post#5, both places where you have R+d, should only have d (since this is already the distance between centers).
Related to Rolling hoop and lagrange multipliers
1. What is a rolling hoop?
A rolling hoop is a physical system in which a circular hoop rolls without slipping on a flat surface. It is an example of a nonholonomic system, meaning that its configuration space is constrained by non-integrable differential equations.
2. How do Lagrange multipliers relate to a rolling hoop?
Lagrange multipliers are used to analyze the motion of a rolling hoop by incorporating the constraint of no slipping into the system's equations of motion. This allows us to determine the forces and accelerations acting on the hoop as it rolls.
3. What is the significance of the Lagrangian in the analysis of a rolling hoop?
The Lagrangian is a function that summarizes the dynamics of a system in terms of its generalized coordinates and their derivatives. In the case of a rolling hoop, the Lagrangian allows us to calculate the kinetic and potential energy of the system, which are essential for determining its equations of motion.
4. Can Lagrange multipliers be applied to other physical systems?
Yes, Lagrange multipliers can be applied to a wide range of physical systems, not just rolling hoops. They are commonly used in mechanics, physics, and engineering to analyze systems with constraints and determine their equations of motion.
5. Are there any limitations to using Lagrange multipliers in the analysis of a rolling hoop?
One limitation of using Lagrange multipliers in the analysis of a rolling hoop is that it assumes the hoop is perfectly circular and the surface it is rolling on is completely flat. In reality, there may be imperfections in the hoop and surface that can affect its motion. Additionally, the equations of motion derived using Lagrange multipliers may not accurately represent the system's behavior at high speeds or in non-ideal conditions.
