Rolling without slipping over a plank
In summary, if the static friction between the cylinder and the plank is less than the tension force, then the centre of mass of the system will not undergo translational motion.
(Ron)^2=-1
This is just a general case I'm having trouble trying to imagine:
https://lh3.googleusercontent.com/-mTyOwzfLy0E/VluaNlxEddI/AAAAAAAAAEk/2Creguw3xzY/w530-h174-p-rw/Screenshot%2Bfrom%2B2015-11-29%2B21%253A34%253A50.png
Suppose there is a cylinder, kind of like a yo-yo, that is being pulled by a massless string. The string does not slip and the yo-yo is rolling without slipping on top of a plank, there is no friction between the plank and the horizontal surface.
Torque, Pure rotating condition
My question is: since the plank does slips over the horizontal surface, then Is the velocity of the cylinder's centre of mass = 0 ? (Assuming Tension < Static Friction between the cylinder and the plank)
It's worth mentioning that the problem doesn't say anything about friction between the plank and the yo-yo, but I thought there must be friction because of the rolling without slipping condition
Thank you!
Looks like you included a diagram or link to a diagram, but it's broken. So please clarify the set-up. Is it:
Smooth horizontal surface.
Plank lies on horizontal surface.
Cylinder on plank, axis horizontal and at right angles to plank, rolling contact.
String wrapped around cylinder, being drawn off horizontally, parallel to the plank, from the top of the cylinder.
https://lh3.googleusercontent.com/-FQFbA0n6chNSwQwUE9jUwaEgA_EDDnwEXjPbTQBRg=w1366-h768-rw
Here is the diagram. If you can't see it here is the set-up
The cylinder is on top of the plank, and the plank lies in a smooth horizontal frictionless surface. The cylinder has a radius R and also a inner radius a, the string is wrapped around the inner radius (a) and its been pulled horizontally, parallel to the surface and the plank.
Thank you for your help!
Here is the diagram, sorry I was having trouble with the link.
It looks like the force ##\vec{F}## is the tension force you mentioned. Aren't that, and the static friction exerted on the cylinder by the plank, the only forces acting on the cylinder in the horizontal direction?
Ah, that's rather different.
I don't see how the cylinder's centre of mass could fail to move. The only external horizontal force on the cylinder+plank is to the right, so the mass centre of that system must go to the right. If the cylinder's centre stays put then the plank goes to the left.
Also, I think you mean acceleration, not velocity.
Mister T said:
It looks like the force ##\vec{\displaystyle F}## is the tension force you mentioned. Aren't that, and the static friction exerted on the cylinder by the plank, the only forces acting on the cylinder in the horizontal direction?
Yes, you're right Mister. Although the problem says nothing about friction between the plank and the cylinder, I thought because of the condition of pure rotation there must be static friction, otherwise the cylinder would just slip.
What I thought was that because the plank can slide over the horizontal smooth surface and assuming Force < Max static friction, then the cylinder will start rotating but the centre of mass will not undergo translational motion and then the velocity will be = 0 (all with respect to a reference frame fixed on the cylinder's centre of mass)
That's right, there is. But the static frictional force never exceeds the force necessary to prevent slipping. Thus, it is surely less than F.
Likes (Ron)^2=-1
Sorry here I meant a reference frame fixed to the initial position
actual static friction <= max static friction
actual static friction < F (since the cylinder must accelerate to the right)
How F compares with max static friction we don't know and don't care.
Likes (Ron)^2=-1
Thank you so much!, I finally got the idea. So the centre of mass must, indeed, have acceleration in order for the pure rotation condition to hold.
Yes, although I think it would also accelerate to the right if there were no friction between cylinder and plank. F would be the only horizontal force acting.
Likes (Ron)^2=-1
Related to Rolling without slipping over a plank
1. What is rolling without slipping over a plank?
Rolling without slipping over a plank is a type of motion where a rigid body, such as a ball or cylinder, moves along a flat surface without sliding or skidding. This type of motion is characterized by both rotation and translation.
2. What factors affect rolling without slipping over a plank?
The two main factors that affect rolling without slipping over a plank are the mass and radius of the object, as well as the coefficient of friction between the object and the surface it is rolling on. Other factors such as the shape and surface area of the object may also play a role.
3. How does rolling without slipping over a plank differ from pure rolling?
Pure rolling is a type of motion where a rigid body moves along a flat surface with only rotational motion and no translation. Rolling without slipping over a plank, on the other hand, involves both rotational and translational motion. In pure rolling, the point of contact between the object and surface is stationary, while in rolling without slipping, the point of contact is moving.
4. What is the relationship between the velocity and angular velocity in rolling without slipping over a plank?
In rolling without slipping, the linear velocity of the object is equal to the product of its angular velocity and radius. This means that as the angular velocity increases, so does the linear velocity. However, the two velocities are not directly proportional, as the radius of the object also plays a role.
5. How is the work-energy theorem applied to rolling without slipping over a plank?
The work-energy theorem states that the work done on an object is equal to the change in its kinetic energy. In rolling without slipping, the work done by friction is equal to the change in the rotational kinetic energy of the object. This can be used to calculate the speed and acceleration of the object as it rolls without slipping over a plank.
  • Mechanics
