Room heat loss to open door? - Program Idea
In summary, the author is trying to figure out how much energy is lost to ventilation when an open door is present. He has found data on the effects of wind on ventilation rates, and is working to find a formula that can be used to calculate the energy lost to ventilation in an open door situation.
mkjt88
Hello all. I've been teaching myself C++ programming and had an idea for a project. I am building a calculator for the heat loss of a room when an outside door/window is open. I'm currently writing out the functions I need to make this happen... Now what I need help with is this. I can't seem to stumble upon a formula I can use to test ambient air to outside air temps through the means of wind or just exposing the two through the door. I guess it's not the best explanation but do you get what I mean?? I plan to add in three variables if necessary to match if higher wind speeds were forcing more cold air in. Anyway any help on how to solve this would be much appreciated.
Science news on Phys.org
That's a tricky problem. Consider.. How does any air get in if there is no way for the air to get out? I can think of two mechanisims...
1) Turbulence - allowing air to enter one part of the door opening and exit via another.
2) Convection - cold air enters at the bottom and warm air leaves at the top.
I can see a host of factors altering the amount of ventilation an open door provides. I doubt it's going to be possible to calculate all this from first principles. Probably best see if you can google up data on energy lost from real world trials. Perhaps it's been done for retail stores that have open doors?
If you can find data on typical air flow rates through an open door its possible to caculate the implied heat loss..
The power lost to ventilation is given by:
Power = Temperature delta * Volumetric heat capacity of air * flow rate
If air conditioning is involved it's probably more complicated due to the water content to the air.
I haven't read it but a quick scan might give you an idea of the complexity...
http://www.ecbcs.org/docs/annex_20_air_flow_through_large.pdf
Selected quotes..
Airflow Through Large Openings on Buildings
New studies of interzonal airflow and single sided ventilation at seven laboratories in Europe and Canada, have then been canied out in this project's framework and have led to improved models.
The single sided ventilation studies (chapter 4) were designed to determine the effect of wind on the ventilation and/or heat loss rates through openings in one external wall only. Collaboration between four european laboratories led to the following conuibutions :
- CSTB test house at Bouin, France, with horizontal slit, to measure internal pressures and the effect of air compressibility
- BBRI attic test room at Gent, Belgium, with open window, to monitor long term ventilation rates and assess possible correlations with measured parameters including wind, temperature and surface pressures
- BRE office at Garston, England, with open window, to assess the time dependence of
ventilation rates following the opening of the window, due to the combined effect of the wind and the thermal properties of the room.
- EPFL offices at Lausanne, Switzerland, with open window, to study the energy consequences of user behaviour by measuring the time dependence of cooling induced by natural ventilation for rooms of different thermal mass.
Heat loss is a factor of conduction, convection, radiation. As noted already, with an open door it is VERY complicated.
You can find formulas for calculating heat losses in a closed room...In those, an air exchange flow with the outside, as through window and door frames is assumed.
And they have formulas for various temperature differences and outside wind speed.
Hello there,
First of all, it's great to hear that you are teaching yourself programming and have come up with a project idea related to heat loss. I can definitely provide some insights and suggestions to help you with your project.
To calculate the heat loss of a room when an outside door or window is open, you will need to consider various factors such as the temperature difference between the inside and outside, the area of the opening, and the wind speed. The formula you are looking for is known as the heat transfer equation, which calculates the rate of heat transfer between two objects or areas.
The heat transfer equation takes into account the temperature difference, the area of the opening, the thermal conductivity of the materials, and the wind speed. To calculate the temperature difference, you will need to measure the inside and outside temperatures using a thermometer. The area of the opening can be measured by calculating the length and width of the door or window.
The thermal conductivity of the materials can be found in tables or online resources. This value represents how well a material can transfer heat. For example, materials with high thermal conductivity, such as metals, will transfer heat faster than materials with low thermal conductivity, such as wood.
Finally, to factor in wind speed, you will need to use the wind chill factor formula, which takes into account the wind speed and the temperature to calculate the perceived temperature. This perceived temperature is then used in the heat transfer equation to calculate the heat loss.
I hope this helps you with your project. Remember to always double-check your calculations and consider any other factors that may affect heat loss, such as insulation and humidity. Good luck with your project!
Related to Room heat loss to open door? - Program Idea
1. How does opening a door affect room heat loss?
Opening a door allows for a direct exchange of air between the inside of a room and the outside environment. This exchange of air can lead to a significant amount of heat loss from the room, as warm air is replaced by cooler air from outside.
2. What factors contribute to room heat loss when a door is open?
There are several factors that contribute to room heat loss when a door is open. These include the temperature difference between the inside and outside of the room, the size and location of the door, and the duration of time that the door is open.
3. Does the type of door affect room heat loss?
Yes, the type of door can have an impact on room heat loss. For example, a solid wood door may provide better insulation than a hollow metal door, resulting in less heat loss when opened.
4. How can I reduce room heat loss when opening a door?
There are a few ways to reduce room heat loss when opening a door. These include minimizing the duration of time that the door is open, using weather stripping or a draft stopper to seal any gaps around the door, and closing off nearby windows or vents to prevent cold air from entering the room.
5. Is there a way to measure the amount of heat loss from opening a door?
Yes, there are various tools and methods that can be used to measure the amount of heat loss from opening a door. These include using a thermometer to measure the temperature difference before and after opening the door, or using thermal imaging to visualize the heat loss. There are also computer programs and simulations that can estimate the amount of heat loss based on the specific variables of the room and door.
  • General Engineering
  • Thermodynamics
