Roots of a polynomial mixed with a trigonometric function
In summary, the study of roots of a polynomial mixed with a trigonometric function involves analyzing equations where polynomial expressions are combined with trigonometric terms. This interplay can lead to complex behaviors and necessitates techniques from both algebra and trigonometry to understand the nature of the roots. Such analyses often require numerical methods or graphical representations to identify solutions, as closed-form solutions may not always be feasible. The examination of these roots can reveal insights into oscillatory behavior and periodicity influenced by the polynomial characteristics.
vcsharp2003
897
177
The question is as given in the image below and is part of a question bank for Calculus at high school (i.e. grade 12). The correct answer is supposed to be (C) two real roots.
None
When I look at the left hand side of the equation in above question then I can see that the highest degree of x would be 6 after the denominators are eliminated.
I know that a polynomial of degree n will have n roots, but this one is not a pure polynomial since there is also a trigonometric function.
I am confused on how to go about solving this problem. Any pointers would help. Probably something to do with functions chapter in Calculus.
the expression whose roots you want is an expression in y, which becomes, when the bottoms are multiplied out, a polynomial in y of degree 2. There is no trig function left. the trig function is only involved in determining the constants f(1), f(2), and f(3) in this polynomial. So there are at most 2 real roots y of that equation. i.e. first plug in x=1, x=2, and x=3 in the expression for f, and evaluate those constants. then you have an equation on the right, involving only y, and constants. i.e. if f(1) = a, and f(2) = b, and f(3) = c, you are asking about the number of roots of the quadratic equation:
(y-b)(y-c) + (y-a)(y-c) + (y-a)(y-b) = 0. you may need to use the fact that the value of 7sin(x) lies between -7 and 7, (inclusive), or you may need to estimate 7sin(1), 7sin(2), and 7sin(3) to get a handle on a, b, and c.
edit:
oops, I left out the coefficients 1,2,3. so I guess you get something like:
(y-b)(y-c) + 2(y-a)(y-c) + 3(y-a)(y-b) = 0. anyway, you have to do it yourself.
Likes vcsharp2003 and FactChecker
Unless I'm missing something here, it seems a lot to expect students to be able to approximate the value of sinx near 0. Do they allow/expect approximations like sinx~x for x near 0? Though then we need to transform into radians.
Likes vcsharp2003
I agree this is an unreasonable problem. But assuming x is already in radians, One can use a calculator to approximate sin(x) to the nearest integer, for x = 1,2,3, and then show that the discriminant of the quadratic polynomial is positive. Indeed it is over 1.5 million. hence there are two real roots. I dislike such problems, or at least such solutions. minimal thought, maximal tedious computation. Just approximating sin(x) as somewhere between -1 and 1, which does not require a calculator, does not suffice.
Of course one of you may well suggest a clever solution that proves me wrong in disliking this problem. E.g. I have not used calculus, and that is a hint here as to what should be used. But I think calculus tells you nothing about roots of quadratics that algebra does not already tell you.
Likes e_jane and vcsharp2003
Another odd thing about this problem is the suggestion that the polynomial could have only one real root. counted with appropriate multiplicity, a quadratic never has only one real root. i.e. many texts assume that when we say a polynomial has "two roots" we allow the possibility that they are equal, but whether that is meant here is not made clear.
edit:
Thanks for your answer.
I was assuming that y needs to be substituted by f(x) resulting in an equation involving x, which was what was making it impossible to solve. The reason why I assumed this is because in Calculus we generally take it for granted that y=f(x).
The angle in these trigonometric ratios of sin 1, sin 2 and sin 3 must be treated as radians.
1 radian is about 57 degrees, 2 radians is about 114 degrees and 3 radians is about 171 degrees.
So, we cannot use the assumption that sin x = x since the angle x in these cases are nowhere close to 0 radians.
After understanding the question based on your post, I tried to go about it, but its far too complex since another requirement we have is that no calculator is allowed.
My analysis is as below.
Let ##a=f(1)##, ##b=f(2)## and ##c=f(3)##.
I can easily see that ##a= 102 + 7\sin{1} \approx 102##, ##b= 212 + 7\sin{2} \approx 212## and ##c= 336 + 7\sin{3} \approx 336##.
I end up with the following quadratic equation after simplification.
$$6y^2-(5a+4b+3c)y + (2ac + 3 ab+ bc) = 0$$
If I now let ##m = 5a+4b+3c## and ##n= 2ac + 3 ab+ bc##, I end up with the following equation.
$$6y^2-my+n = 0$$.
Clearly we'll have two roots for the above equation whose nature will depend on the sign of the discriminant, which is ## m^2 - 24n##. The problem arises at this stage since we need to decide the sign of this discriminant without using a calculator, but just manual calculations or some mathematical trick. Do you know of a simpler method to determine the sign other than substituting the approximate value of ##a##, ##b## and ##c## into the discriminant?
I think the reason its under Calculus is because the first chapter in our Calculus course is Functions where the concept of ##f(x)## is explained. Here we need to use that concept since we need to know what ##f(1)##,##f(2)## and ##f(3)## mean.
$$6y^2-my+n = 0$$.
It should be farily easy to calculate [tex]\begin{split}
m^2 - 24n &= 25a^2 + 16b^2 + 9c^2 + (40 - 72)ab + (30 - 48)ac + (24 - 24)bc \\
&= 25a^2 + 16b^2 + 9c^2 - 32ab - 18ac \\
&= A^2 + B^2 + C^2 - \tfrac45 AB - \tfrac 65AC\end{split}[/tex] where [itex]A = 5a[/itex], [itex]B = 4b[/itex] and [itex]C = 3c[/itex]. Now you can complete the square: [tex]
\begin{split}
m^2 - 24n &= (A - \tfrac25B - \tfrac35C)^2 + \tfrac{21}{25}B^2 + \tfrac{16}{25}C^2 - \tfrac{12}{25} BC \\
&= (A - \tfrac25B - \tfrac35C)^2 + \tfrac{1}{25}( 4C - \tfrac32 B )^2 + \tfrac34 B^2 \\
&\geq 0.
\end{split}[/tex]
Alternatively, and without doing any algebra at all, you could argue that [tex]g(y) = 1/(y - a) + 2/(y - b) + 3/(y - c)[/tex] for distinct [itex]a[/itex], [itex]b[/itex] and [itex]c[/itex] must cross the zero axis twice because its behaviour at each vertical asymptote is governed by [itex]1/(y - y_0) + C[/itex] which is negative for [itex]y< y_0[/itex] and positive for [itex]y > y_0[/itex].
  • Love
Likes mathwonk and vcsharp2003
I think the answer could be found by realizing that each term, ##\frac {1}{y-f(n)}##, dominates the formula for ##y## near ##f(n)##. Those terms at least force a certain number of zeros. It is not as clear to me how to show that there are not some more zeros. Maybe someone else has ideas about that.
\begin{split}
&\geq 0.
\end{split}[/tex]
Shouldn't ##m^2-24n \gt 0## rather than ##m^2-24n \geq 0##, since the last term after completing the squares is ##\frac {3}{4} B^2## which will always be positive because ##b \approx 212##?
The argument by pasmith in #10 is just beautiful, and exactly the kind of intelligent solution that justifies the problem! So my error was in multiplying out the bottoms and losing the tool of asymptotes. (still it really does not use calculus, or probably some people consider limits as calculus.).
Maybe a complete solution uses a bit more, to rule out further zeroes, as Factchecker points out. I.e. one could use the quadratic approach to argue there are at most 2 solutions, together with the asymptote argument that there are at least 2. Hence both solutions are "simple", i.e. not multiple.
Or one could actually use calculus to compute the slopes of the graph of the fractional equation in y, and since in fact its derivative is never zero (away from a,b,c), then arguing also about the sign of the three terms in the various intervals between a,b,c, that also shows there are exactly two distinct roots, and that the roots have multiplicity one each. but they key is using the original form of the equation in y, and not multiplying out. I.e. one could use calculus to graph the equation in y and eyeball the solutions.
Thank you pasmith, now I really like the solution, and thus grudgingly, also the problem.
Still I don't exactly love it, since the original equation in x was just a smokescreen designed to confuse. I.e. the only data needed from it is that a, b, c, are distinct. So as often happens, the problem is not designed to test knowledge of calculus, but cleverness, i.e. the ability ignore distractions and focus on essential information.
A better argument: Set [itex]g(y) = N(y)/D(y)[/itex] where [tex]\begin{split}
N(y) &= (y - b)(y - c) + 2(y - a)(y - c) + 3(y - a)(y - b) \\
D(y) &= (y- a)(y - b)(y - c)\end{split}[/tex] where [itex]a = f(1) < b = f(2) < c = f(3)[/itex]. We have [tex]
\begin{split}
N(a) &= (a - b)(a - c) > 0 \\
N(b) &= 2(b- a)(b - c) < 0 \\
N(c) &= 3(c- a)(c - b) > 0\end{split}[/tex] so [itex]N[/itex] - which is a quadratic with positive [itex]y^2[/itex] coefficient - has a zero in [itex](a,b)[/itex] and a zero in [itex](b, c)[/itex]. Since [itex]D[/itex] does not vanish at these points it follows that [itex]g = N/D[/itex] has zeroes at these two points and not elsewhere.
(This does rely on the specialization of the IVT to a quadratic with positive leading coefficient which falls below the horizontal axis somewhere, but I think this can be assumed, even in a section introducing the concept of function notation - if you know how to determine how many distinct real roots a quadratic has then you will know what its graph looks like in each of the possible cases.)
Likes FactChecker and mathwonk
this is indeed a nice succinct way to combine the asymptote and quadratic arguments. again it completely avoids calculus, but uses limits in the form of IVT. It also implies of course the two roots are both simple.
FAQ: Roots of a polynomial mixed with a trigonometric function
What are the roots of a polynomial mixed with a trigonometric function?
The roots of a polynomial mixed with a trigonometric function are the values of the variable that satisfy the equation when both the polynomial and trigonometric components are considered. These roots can be real or complex numbers, and finding them often requires numerical methods or specialized techniques.
How do you solve an equation that combines a polynomial and a trigonometric function?
To solve an equation that combines a polynomial and a trigonometric function, you typically use numerical methods such as the Newton-Raphson method, interval bisection, or other root-finding algorithms. Analytical solutions are rare and usually only possible for simple cases.
Can you provide an example of such an equation and its solution?
Consider the equation \( x^2 + \sin(x) = 0 \). To solve this, you can use numerical methods. For example, using the Newton-Raphson method with an initial guess \( x_0 = 0.5 \), you iteratively apply \( x_{n+1} = x_n - \frac{f(x_n)}{f'(x_n)} \) until convergence. Here, \( f(x) = x^2 + \sin(x) \) and \( f'(x) = 2x + \cos(x) \). The solution will be approximately \( x \approx -0.8767 \).
Are there any software tools that can help find the roots of such equations?
Yes, several software tools can help find the roots of equations that mix polynomials and trigonometric functions. Popular tools include MATLAB, Mathematica, and Python libraries such as SciPy. These tools provide built-in functions for numerical root-finding and can handle complex equations efficiently.
What are the challenges in finding the roots of these mixed equations?
Challenges in finding the roots of equations that mix polynomials and trigonometric functions include the potential for multiple roots, both real and complex, and the presence of oscillatory behavior due to the trigonometric component. These factors can complicate the convergence of numerical methods and require careful initial guesses and algorithm selection.
