MHB Roots of a polynomial with non-real coefficients.
For the polynomial equation z^4 + az^3 + bz^2 + cz + d = 0 with all roots on the unit circle, the sum of the reciprocals of the roots is determined to be -c. The roots, represented as conjugate pairs, maintain a magnitude of 1, allowing for simplifications using Vieta's formulas. The calculations confirm that the product of the roots equals d, which is 1 in this case. Thus, the correct answer to the original question is option c) -c. This conclusion highlights the relationship between the roots' properties and their coefficients in polynomial equations.
juantheron
Let a,b,c,d be real numbers. Sauppose that all the roots of the equation $z^4 + az^3 + bz^2 + cz + d = 0$ are complex numbers
lying on the circle $\mid z\mid = 1$ in the complex plane. The sum of the reciprocals of the roots is necessarily:
options
a) a
b) b
c) -c
d) d
---------- Post added at 22:03 ---------- Previous post was at 21:31 ----------
Thanks Friends I have Got it
Let $\alpha\;,\beta\;,\gamma\;,\delta$ be the roots of Given EquationNow all Roots are Imaginary and lie on $\mid z\mid = 1$and Imaginary Roots are always occur in pair so Let $\alpha = x_{1}+iy_{1}\;\;\beta = x_{1}-iy_{1}$ and $ \alpha.\beta = x^2_{1}+y^2_{1} = 1$ Similarly $ \gamma = x_{2}+iy_{2}\;\;\delta = x_{2}-iy_{2}$ ] and $ \gamma.\delta = x^2_{2}+y^2_{2} = 1$ Now Using Vieta, s Formula$ \alpha+\beta+\gamma+\delta = -a$ $ \alpha.\beta.\gamma+\beta.\gamma.\delta+\gamma \delta.\alpha+\delta.\alpha.\beta = -c$ $ \alpha.\beta.\gamma.\delta = d$ So $\displaystyle \frac{\alpha.\beta.\gamma+\beta.\gamma \delta+\gamma.\delta.\alpha+\delta.\alpha.\beta}{\alpha \beta.\gamma.\delta} = -\frac{c}{d} = - c$So $ \displaystyle \frac{1}{\alpha}+\frac{1}{\beta}+\frac{1}{\gamma}+\frac{1}{\delta} = -c$ because $ \alpha.\beta.\gamma.\delta = d=1$
Mathematics news on Phys.org
So Option $ \boxed{\boxed{c}} $ is Correct
I would like to provide a more detailed explanation for why the answer is option c) -c.
Firstly, let's define the four roots of the given equation as $\alpha, \beta, \gamma, \delta$. Since the equation has all complex roots, we know that they will exist in conjugate pairs, i.e. $\alpha$ and $\beta$ will be conjugates, and $\gamma$ and $\delta$ will be conjugates.
Now, we know that the roots of the equation lie on the circle $|z| = 1$ in the complex plane. This means that all the roots will have a magnitude of 1, and therefore can be represented in polar form as $e^{i\theta}$, where $\theta$ is the argument of the root.
Since the roots exist in conjugate pairs, we can write them as $e^{i\theta}$ and $e^{-i\theta}$. Now, using Euler's formula, we can expand these roots as $\cos\theta + i\sin\theta$ and $\cos\theta - i\sin\theta$, respectively.
Next, let's look at the sum of the reciprocals of the roots. This can be written as $\frac{1}{\alpha} + \frac{1}{\beta} + \frac{1}{\gamma} + \frac{1}{\delta}$. Using the expanded forms of the roots, we can simplify this expression as $\frac{\cos\theta - i\sin\theta}{\cos\theta + i\sin\theta} + \frac{\cos\theta + i\sin\theta}{\cos\theta - i\sin\theta} + \frac{\cos\theta - i\sin\theta}{\cos\theta + i\sin\theta} + \frac{\cos\theta + i\sin\theta}{\cos\theta - i\sin\theta}$.
Now, using the formula for complex conjugates, we can simplify this expression even further to $\frac{\cos^2\theta + \sin^2\theta}{\cos^2\theta + \sin^2\theta} = 1$. Therefore, the sum of the reciprocals of the roots is simply 1.
Finally, using Vieta's formulas, we
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
