Roots of an irreducible polynomial over a finite field
In summary, in the field $\Bbb Z_2(a)$, the elements $a^2$ and $a^2+a$ are both zeros of the polynomial $x^3+x+1$. This can be shown by computing $f(a^2)$ and $f(a^2+a)$ and showing that both equal zero. Thus, $a^2$ and $a^2+a$ are both roots of $f(x)$ in $\Bbb Z_2(a)$.
Scherie
Let F=Z2 and let f(x) = X^3 +x+1 belong to F[x]. Suppose that a is a zero of f(x) in some extension of F.
Using the field created above F(a)
Show that a^2 and a^2+a are zeros of x^3+x+1?
If $a$ is a root of $x^3 + x + 1 \in \Bbb Z_2[x]$, it follows that in $\Bbb Z_2(a)$, we have:
$a^3 = a + 1$ (recall that in any field of characteristic $2$, we have $b = -b$, for any element $b$).
It is straightforward to compute $f(a^2)$:
$f(a^2) = (a^2)^3 + (a^2) + 1 = (a^3)^2 + a^2 + 1 = (a+1)^2 + a^2 + 1$
$= a^2 + (a+a) + 1 + a^2 + 1 = a^2 + 0 + 1 + a^2 + 1 = (a^2 + a^2) + (1 + 1)$
$= a^2(1 + 1) + (1 + 1) = (a^2 + 1)(1 + 1) = (a^2 + 1)(0) = 0$.
This shows $a^2$ is likewise a root of $f$, since $f(a^2) = 0$.
Now can you do the same with $a^2 + a$?
FAQ: Roots of an irreducible polynomial over a finite field
What is an irreducible polynomial over a finite field?
An irreducible polynomial over a finite field is a polynomial that cannot be factored into polynomials of lower degree over the same finite field. In other words, it cannot be broken down into smaller, simpler factors.
What is the significance of roots of an irreducible polynomial over a finite field?
The roots of an irreducible polynomial over a finite field represent the elements of a finite field extension. This allows for the construction of larger finite fields, which are necessary for many applications in mathematics and computer science.
How do you find the roots of an irreducible polynomial over a finite field?
There are various methods for finding the roots of an irreducible polynomial over a finite field, such as using the Berlekamp algorithm or the Cantor-Zassenhaus algorithm. These algorithms can efficiently compute the roots of an irreducible polynomial over a finite field.
Can an irreducible polynomial over a finite field have multiple roots?
No, an irreducible polynomial over a finite field can only have simple roots. This means that each root has a multiplicity of 1, and there are no repeated roots.
What are some real-world applications of studying the roots of an irreducible polynomial over a finite field?
The roots of an irreducible polynomial over a finite field have numerous applications in cryptography, error-correcting codes, and coding theory. They are also used in various areas of mathematics, such as algebraic geometry and number theory.
