Roots of Complex Numbers (proof)
In summary, the problem at hand is to prove that for any nth root of unity, other than 1, the sum of its powers from 0 to n-1 is equal to 0. The attempt at a solution involves using the fact that c^n = 1 and c \not = 1, and simplifying the equation (c-1)(1 + c + c^2 + \cdots + c^{n-1}) = (c)(1 + c + c^2 + \cdots c^{n-1}) + (-1)(1 + c + c^2 + \cdots + c^{n-1}). By equating the start and final expressions, it can be
DEMJ
44
If c is any nth root of unity other than 1, then
[tex] 1 + c + c^2 + \cdots + c^{n-1} = 0[/tex]
This is what is done so far and I am at a dead stall for about 2 hours lol. Any ideas on what I should be thinking of next? Should I continue simplifying? I have tried to continue simplifying but it always leads to nothing relevant. Do I need to be using [tex]re^{i\theta}[/tex] ?
Proof:
Assume [tex]c^n = 1[/tex] and [tex]c \not = 1[/tex]. Then [tex]c^n -1 = 0[/tex]. Note that
[tex](c-1)(1 + c + c^2 + \cdots + c^{n-1}) = (c)(1 + c + c^2 + \cdots c^{n-1}) + (-1)(1 + c + c^2 + \cdots + c^{n-1}) = c + c^2 + c^3 + \cdots + c^n - 1 - c - c^2 - \cdots - c^{n-1}[/tex]
my browser doesn't show tex properly, but simplify your final equation by cancelling terms & i think you're pretty much there...
you have shown c-1 does not = 0, and you know c^n-1=0, so what does equating your start & final expressions tell you?
[tex]S=1 + c + c^2 + \cdots + c^{n-1}[/tex]
[tex]Sc=c+c^2+c^3 + \cdots + c^{n}[/tex]
[tex]Sc-S=c^n-1[/tex]
[tex]S(c-1)=c^n-1[/tex]
[tex]S=\frac{c^n-1}{c-1}[/tex]
So you got
[tex]\frac{c^n-1}{c-1}=0[/tex]
I think you can solve it now. :wink:
FAQ: Roots of Complex Numbers (proof)
What are complex numbers?
Complex numbers are numbers that consist of a real part and an imaginary part. They are written in the form a + bi, where a is the real part and bi is the imaginary part with i being the imaginary unit (√-1).
How are complex numbers related to the roots of quadratic equations?
Complex numbers are closely related to the roots of quadratic equations because they are the solutions to equations of the form ax^2 + bx + c = 0. The roots of a quadratic equation are the values of x that make the equation equal to 0. In some cases, the roots of a quadratic equation may be complex numbers.
What is the proof for finding the roots of complex numbers?
The proof for finding the roots of complex numbers is known as the quadratic formula. It is used to find the solutions to a quadratic equation and is written as x = (-b ± √(b^2 - 4ac)) / 2a. This formula works for both real and complex numbers.
How do we know that the quadratic formula works for complex numbers?
The quadratic formula works for complex numbers because it uses the fundamental laws of arithmetic and algebra, which apply to both real and complex numbers. Additionally, the proof for the quadratic formula involves using basic algebraic manipulations to solve the equation and obtain the roots.
Can complex numbers have more than two roots?
Yes, complex numbers can have more than two roots. For example, the equation x^4 = 1 has four roots: 1, -1, i, and -i. These roots can be found by using the quadratic formula to find the roots of the quadratic equation x^2 = 1, which gives us the two complex roots i and -i. This shows that complex numbers can have multiple roots, just like real numbers.
