Potatochip911
- 318
- 3
A rope with uniform density ##\lambda=\frac{m}{L}## is placed on a frictionless table with an initial length ##y_0## hanging through the hole. Derive a differential equation for the position of the bottom of the rope and then using this solve for the time required for the rope to leave the table.
##p=mv##
##F=\frac{dp}{dt}##
##p=\dot{m}v+m\dot{v}##
I'm currently stuck with determining which differential equation I've derived is the correct one (although they only differ slightly).
The first method is just by analyzing the motion in the y direction. The acceleration will be given by ##ma=\lambda gy## where ##m## is the mass of the entire rope and ##y## (a function of time) is the length of the rope that's fallen through the hole. We can rewrite ##m## as ##\lambda L## from which we obtain: ##a=\frac{gy}{L}## or written more conveniently $$\ddot{y}-\frac{g}{L}y=0$$
The second method is the way my professor suggested to go about solving it. We consider the forces in both the ##x## and ##y## directions. To do this I considered the mass on the table ##m_T## and the mass falling off the table ##m_F## separately. Defining the ##x## and ##y## axis so the movement on the x and y-axis will be positive, in the x direction we have $$F_x=\frac{dp}{dt}=\dot{m_T}v+m_T\dot{v}\hspace{5mm} \mbox{and} \hspace{5mm} F_y=\dot{m_F}v+m_F\dot{v}$$ Then using the relation ##\dot{m_T}=-\dot{m_F}## we can express the first equation as ##F_x=-\dot{m_T}v+m_T\dot{v}##. Now the same force ##\lambda gy## will act on both of the sections therefore $$F_x+F_y=2\lambda gy=\dot{v}(m_F+m_T)$$ Now using ##m_F=y\lambda## and ##m_T=\lambda(L-y)## we get ##2\lambda gy=\dot{v}\lambda L## which after cancelling terms and changing to a more convenient form: $$\ddot{y}-\frac{2g}{L}y=0$$
I feel like something is definitely off about the second method particularly with how the force is acting on the masses but I just can't see what.
