Ropes Pulleys Help Exam 2morrow
In summary, the equations to use for this problem are: a = (T - Ff) / m1 for the mass on the surface and a = (Fg - T) / m2 for the mass suspended in the air. These equations can also be combined to solve for the tension T.
Mightiestmike
Ok, if you had a question where a cart (m1) is resting on a surface, and is attached to a string passing over a frictionless pulley, off of which another mass (m2) is suspended in the air, what is the equation that I use?
It is like an atwood machine, except m1 is on a surface, and, I need to take into account the friction affecting m1.
it is hard cause my tect book only shows me how to derive an equation from
Fnet = ma when there is no friction on the surface. But I know it will have friction in the exam.
You use the one and only equation governing all of mechanics. [itex]\Sigma \vec{F} = m\vec{a}[/itex].
Is your problem that you don't know what the form of the frictional force is?
Post your work if you need assistance. And also post exactly what the question is; i.e. what do they want you to find and what do you know about the initial conditions.
Solved it! I think.
For the Mass on the Surface:
a = (T - Ff) / m1
For the Mass suspended in the air:
a = (Fg - T) / m2
I am not sure which is correct, is a = (Fg - T) / m2 correct and you don't take m1 into account because the force on that is caused by T which is already in the equation? or must you put it in the equation like that of an Atwood Machine?
a = (Fg - T) / (m1 + m2)
Atwood Machine:
a = (m2-m1)g / (m1 + m2)
I have a Feeling that the First 2 are correct because I found them in my notes, however I could have copied them incorrectly.
Yes, these are the correct equations of motion. You may combine them to find the tension T, knowing from experience that the acceleration a, is the same for both block.
FAQ: Ropes Pulleys Help Exam 2morrow
1. What are ropes and pulleys used for in science?
Ropes and pulleys are simple machines that work together to make lifting and moving objects easier. They are commonly used in science experiments to demonstrate concepts such as force and mechanical advantage.
2. How do ropes and pulleys work together?
Ropes are attached to a pulley, which is a wheel with a groove around its circumference. When the rope is pulled, the pulley rotates, changing the direction of the force and making it easier to lift heavy objects.
3. What is the difference between a fixed pulley and a movable pulley?
A fixed pulley is attached to a stationary object, while a movable pulley is attached to the object being lifted. A fixed pulley changes the direction of the force, while a movable pulley also provides a mechanical advantage by distributing the weight of the object between multiple ropes.
4. How can ropes and pulleys be used to calculate force and mechanical advantage?
By counting the number of ropes supporting the object and the number of pulleys in the system, scientists can determine the mechanical advantage, or the amount of force gained by using the machine. They can also use formulas to calculate the force needed to lift a certain weight using ropes and pulleys.
5. What are some real-life applications of ropes and pulleys?
Ropes and pulleys are used in a variety of industries, such as construction, transportation, and entertainment. They are also commonly used in everyday objects, such as elevators, cranes, and exercise equipment.
9K
