valentinemiss
- 1
Two concentric circular loops of wire carrying current in the same direction lie in the same plane. Loop 1 has radius 1.8cm and carries 3.6 mA. Loop 2 has radius 2.3cm and carries 6 mA. Loop 2 is to be rotated about a diameter while the net magnetic field set up by the two loops at their common center is measured. Through what angle must loop 2 be rotated so that the magnitude of the net field is 99 nT?
Bnet = B2 - B1
B1 = u*i / 2R = B2
I found B1 to equal 1.26E-7 using the formula above but B2 is where I get stuck. I am not sure where to factor in the angle. I know after I get that figured out I can plug in the values for Bnet and B1 and solve for theta in the B2 formula. You don't need to solve it for me just give me a hint or place to start.
