PathEnthusiast
- 8
- 1
I have been doing some reading about birefringence in order to understand colors observed in different birefringent crystals when I came across the following page in connection with calcite crystal birefringence.
https://www.microscopyu.com/tutorials/birefringence-in-calcite-crystals
I think I understand why there are two images produced and why the polarizers can eliminate light from each image: the refractive index the crystal imposes for light polarized perpendicular to the optical axis of the crystal is close enough to air that the light path is not obviously distorted for light polarized in that direction, whereas light polarized parallel to the optical axis experiences a refractive index far enough from air that the light path is significantly distorted, producing an image offset from what one would expect for an ordinary transparent object. Because the refractive indices and therefore the light paths are polarization-dependent, an appropriately oriented polarizer can eliminate light corresponding to each of the images. So far so good. What I'm having trouble understanding is why rotating the crystal causes precession. If I imagine replacing the crystal with a material having a single refractive index, it seems to me I should be able to recreate the scenario for each of the rays of light. But when I do that exercise I don't see any reason the image should rotate. If I rotated an ordinary glass of water, I don't expect to see the refracted image shift as I rotate the glass. So why is the crystal causing rotation? Is there a decent mathematical treatment of this phenomenon somewhere that I could review to better understand the rotational aspect?
Thanks in advance!
Thanks in advance!
