Rotating climbing wall - Components selection
In summary, the conversation is about a mother of three boys who is looking for help in building a rotating climbing wall for their garage. The specific components mentioned are a hydraulic unit, a lever for adjusting pressure, and a mechanical lock for safety. The responders caution against attempting the project without proper knowledge and advise seeking help from local climbing enthusiasts.
Climbingwall
Hello to all members!
I'm looking for specific names of 3 mechanical components from the video:
Component name 1: min 0:52 from the video
Component name 2: min 1:01 from the video
Component name 3 (the brake): min 3:53 from the video
Perhaps anyone also has a link to the 3 components?
I would be very grateful for any help! 😊
PS:
I am the mother of 3 boys who really want to have a rotating climbing wall in their garage.
Unfortunately, I have no much of technical knowledge and therefore ask for your help. We are currently in the early stages of the project and are looking to see if we can implement it ourselves.
Welcome to PF.
It will take a bit of thinking to fully understand, reverse engineer, or improve the mechanism, but here is a summary so far.
1. The hydraulics unit is probably a small hydraulic pump driven by the top shaft. By restricting the fluid flow rate, the sink rate of the wall can be regulated.
2. The lever probably adjusts the hydraulic pressure before the fluid flows, so the wall can be used by people of different weight.
3. Your immediate response to getting your foot caught at the bottom of the machine would be to pull yourself up using the hand holds, which would make things worse. The bottom slat mechanical lock is probably a safety feature that prevents you getting your foot trapped under the machine.
If a patent exists, it would be interesting to know the patent number.
There are solutions other than hydraulics available to control the wall sink rate.
Welcome to PhysicsForums. Unfortunately, this project has enough dangerous aspects that we will not be able to help you beyond the post above. Perhaps you can find local climbing enthusiasts who can help with this project. Good luck, and please be safe.
Likes anorlunda
FAQ: Rotating climbing wall - Components selection
What factors should be considered when selecting components for a rotating climbing wall?
There are several important factors to consider when selecting components for a rotating climbing wall. These include the weight and strength of the materials, the durability and reliability of the components, the ease of maintenance and repair, and the cost of the components.
How do you determine the appropriate size and shape of the rotating climbing wall?
The size and shape of the rotating climbing wall should be determined based on the available space, the intended use of the wall, and the skill level of the climbers. It is important to ensure that the wall is large enough to accommodate multiple climbers and that it has a variety of holds and routes to challenge different abilities.
What type of motor is best suited for a rotating climbing wall?
The type of motor best suited for a rotating climbing wall will depend on the size and weight of the wall, as well as the desired speed and rotation. Generally, a high-torque motor with variable speed control is recommended to ensure smooth and controlled movement of the wall.
How do you ensure the safety of climbers on a rotating climbing wall?
The safety of climbers on a rotating climbing wall is of utmost importance. It is essential to use high-quality, durable materials for the wall and its components, and to regularly inspect and maintain the wall to ensure it is in good working condition. It is also important to provide proper safety equipment, such as harnesses and helmets, and to have trained staff on hand to supervise and assist climbers.
Can a rotating climbing wall be used for both indoor and outdoor settings?
Yes, a rotating climbing wall can be used in both indoor and outdoor settings. However, the components and materials used may vary depending on the environment. For outdoor use, weather-resistant materials and protective coatings may be necessary to ensure the longevity and safety of the wall. Additionally, proper anchoring and support structures may be required for outdoor use.
79K
9K
