Rotating disk/ sphere and moving mass along it
In summary, the Coriolis effect is the phenomenon that causes objects to move to the west on a rotating planet. The effect is magnified in a non-friction system, and can be used to generate energy.
Edi
177
Coriolis effect - In a non-friction system, f I roll something along the surface of the planet from on of the poles to the equator, it will appear to move to the west, it will essentially stay behind the planets rotation and actually rotate it in the opposite direction. Now, if we add friction to the system, the planet will accelerate the ball. The question is - will the planet system as a whole slow down? As I understand it should work the same with a spinning ballerina, who rotates with arms pulled to chest, expands them straight out and slows herself rotating.
And the opposite - if we roll the ball from equator to pole in non friction system, it will "go ahead" the planet, as it has more energy/ speed than lower points of the planet. Then, if we ad friction, the planet will slow down the ball and and the whole planet system will accelerate again? (again the ballerina effect)
(more questions will come after this, if the answer is, in shorts, - yes)
The angular momentum has to be conserved, so having the planet accelerate the ball will affect the planet's rotation accordingly.
Note that you won't be able to get a rolling ball back to the poles, in a frictionless system. At best you can make it cross the poles while traveling in a circle along the meridian lines.
The only way to do it is to stop the ball first.
Then the answer is "yes", yes?
Well, yes, the ball won't get back to the pole, but it will go .. up/ down/ away from the equator, right? And the "And the opposite - " part of my first post will be true, right?
So, yes, the angular momentum has to be conserved - just as I thought.
BUT, in that case - if the friction that accelerates the ball is a, say, piezoelectric crystal attached to the surface of the planet in with the ball smacks into and when the ball strikes it, it not only accelerates (deceleration is just acceleration in the opposite direction anyway) the planet, but also generates electricity from the impact? What then? The electric energy eventually turns in heat and some of that will even radiate away from the planet, in space.
So.. the planet slows down .. because energy is somehow pumped out of its rotation or.. what?
Yessir. It's a "yes".
Both regular friction, and having some more esoteric setup like the one you've described, convert the kinetic energy of the planet's rotation into other kinds of energy.
In the idealised situation, where both bodies are completely rigid and the collisions are perfectly elastic, then all of the momentum of the planet would be transferred into the ball.
But since there are no such ideal setups in reality, there are always additional losses, mostly in the form of heat. So the total kinetic energy of the system(and angular momentum) after the ball is accelerated(whichever way) will be less than before due to the heating of the ball/surface due to friction, or/and other energy siphons you might put in there.
In other words, yes, the planet can be slowed down this way.
So.. does that mean that sufficiently industrial species (us, humans?) can use a mechanism such as this to pump out energy from the planets rotation and use it to generate more usable forms of energy for our use (heat to electricity..) ?
Rotation would be very hard to do, but you can google for "tidal power generation" to see how we routinely capture some of the moon's kinetic energy as it orbits the earth.
Thank you, I know about the tidal power generation, but I found it harder to google for what I am talking about here - is there some research about this that I could read about?
FAQ: Rotating disk/ sphere and moving mass along it
What is the purpose of studying rotating disks/spheres and moving mass along them?
The study of rotating disks/spheres and moving mass along them helps us understand the principles of motion and mechanics. It also has practical applications in fields such as engineering and physics.
How does the mass of an object affect its motion on a rotating disk/sphere?
The mass of an object affects its motion on a rotating disk/sphere by determining the amount of force needed to move it and the speed at which it rotates. Objects with larger masses require more force to move and will rotate at a slower speed compared to objects with smaller masses.
What factors influence the rate of rotation on a rotating disk/sphere?
The rate of rotation on a rotating disk/sphere is influenced by factors such as the mass and shape of the object, the force applied, and the friction between the object and the disk/sphere. The distance from the center of rotation and the distribution of mass also play a role in determining the rate of rotation.
How does the direction of motion affect the rotation of a disk/sphere?
The direction of motion affects the rotation of a disk/sphere by changing the forces acting on the object. For example, if an object is moving in the same direction as the rotation of the disk/sphere, it will experience less friction and rotate faster. However, if the object is moving in the opposite direction, it will experience more friction and rotate slower.
What is the difference between centripetal and centrifugal force in a rotating disk/sphere?
Centripetal force is the inward force that keeps an object moving in a circular path on a rotating disk/sphere. It is caused by the tension in a string or the normal force from the surface. On the other hand, centrifugal force is the outward force that an object experiences due to its inertia and the rotation of the disk/sphere. It is a pseudo-force and does not actually exist, but it can be used to explain the motion of objects on a rotating disk/sphere.
