Kennedy
- 70
- 2
A uniform rod (length = 2.4 m) of negligible mass has a 1.0-kg point mass attached to one end and a 2.0-kg point mass attached to the other end. The rod is mounted to rotate freely about a horizontal axis that is perpendicular to the rod and that passes through a point 1.0 m from the 2.0-kg mass. The rod is released from rest when it is horizontal. What is the angular velocity of the rod at the instant the 2-kg mass passes through its low point? (a) 1.7 rad/s (b) 2.2 rad/s (c) 2.0 rad/s (d) 1.5 rad/s (e) 3.1 rad/s
I'm thinking that using the cross product of the radius and the torque is relevant (rFsinθ), and probably the equivalent of the equations of linear motion for rotational dynamics. I would also assume that Newton's Second Law for rotational dynamics applies (τ = Iα).
First I calculated the force of gravity that would act on both point masses. So, 9.8 N for the 1.0-kg point mass, and 19.6 N for the 2.0-kg point mass. Since they're both point masses, I would assume that the torque acts at both ends of the rod. So, the torque on the 2.0-kg point mass would be 19.6 N(1 m) = 19.6 N*m, and for the 1.0-kg point mass would be 9.8 N(1.4 m) = 13.72 N*m. Because the mass of the rod is negligible, the rotational inertia is completely due to the point masses. So, I = 1(1.4^2) +2(1^2) = 3.96 kg*m^2. The net torque is 19.6 - 13.72 = 5.88 N*m. This yields the angular acceleration to be 5.88/3.96 = 1.48 rad/s^2.
Since the rod starts out horizontally, and it rotates in the direction of the 2.0-kg point mass, when the system rotates an angle of θ = pi/2, the 2.0-kg point mass is at its low point. By using the equivalent of the equations of linear motion for rotational dynamics, I solved for the final angular velocity of the 2.0-kg point mass at its low point. This gave me 2.15 rad/s, which is not the correct answer.
I was shown how to do the problem using energy conservation, but shouldn't I be able to solve the problem using this method. What's wrong with my approach?
