Rotation and Polarisation of Light using Jones Matrices
The discussion centers on solving a problem involving the rotation and polarization of light using Jones matrices. The user successfully applies the rotation matrix but struggles with simplifying the resulting equation to find the angle θ. They express the equation in terms of a quadratic in tan(θ) but suspect a simpler solution exists. Another participant confirms the user's work and provides a clearer path to the solution, suggesting a relationship between sin(2θ) and cos(2θ) that leads to a simplified expression for θ. Additionally, they correct the terminology from "Jones matrix" to "Jones vector."
Mr_Allod
a) Rotate an arbitrary Jones matrix ##\vec J = \begin{bmatrix} A \\ Be^{i\delta} \end{bmatrix}## using ##R(-\theta)##
b) At a particular angle ##\theta## this rotation should result in an elliptically polarized wave of the form ##\begin{bmatrix} A' \\ iB' \end{bmatrix}## where the ##\hat x## and ##\hat y## components of this new Jones vector are orthogonal in the complex plane. Find this angle by computing the dot product of these components on an Argand Diagram and setting it equal to zero.
##R(-\theta) = \begin{bmatrix} \cos\theta && \sin\theta \\
-\sin\theta && \cos\theta \end{bmatrix}##
##e^{i\delta} = \cos\delta + i\sin\delta##
##\cos^2\theta - \sin^2\theta = \cos2\theta##
##\cos^2\theta + \sin^2\theta = 1##
##\sin\theta\cos\theta = \frac 1 2 \sin2\theta##
Hello there I am having trouble with part b) of this exercise. I can apply the rotation matrix easily enough and get:
R(-\theta) \vec J= \begin{bmatrix} A\cos\theta + B\sin{\theta}e^{i\delta} \\
-A\sin\theta + B\cos{\theta}e^{i\delta} \end{bmatrix}
I decided to convert the exponential into it's trigonometric components to make it easier to represent on an Argand Diagram:
R(-\theta) \vec J= \begin{bmatrix} (A\cos\theta + B\sin\theta\cos\delta) + iB\sin\theta\sin\delta \\
(-A\sin\theta +B\cos\theta\cos\delta) + iB\cos\theta\sin\delta \end{bmatrix}
Now I take the dot product of the real and imaginary components like so: $$(a\hat r +b\hat i) \cdot (c\hat r + d\hat i) = ac + db$$
Which gives me:
$$(A\cos\theta + B\sin\theta\cos\delta)(-A\sin\theta +B\cos\theta\cos\delta) + (B\sin\theta\sin\delta)(B\cos\theta\sin\delta)$$
And after multiplying out and using some trig. identities I can simplify it to:
$$-A^2\sin\theta\cos\theta + AB\cos2\theta\cos\delta + B^2\sin\theta\cos\theta$$
$$= \frac 1 2 \sin2\theta(B^2-A^2) + AB\cos2\theta\cos\delta = 0$$
From here the only thing I could thing of doing is expressing everything in terms of a quadratic of ##\tan\theta## and getting an answer for ##\theta## by taking the ##\tan^{-1}## of the roots. That of course gives two very complicated expressions in terms of ##A, B## and ##\cos\delta## and I have a suspicion the actual answer should be much neater. I wonder if there is some assumption I can make that would simplify it? Or is there some point earlier in the analysis where I can determine a value for ##\theta## just by visual inspection? If someone could help me with this I would appreciate it.
Likes vanhees71 and PhDeezNutz
Mr_Allod said:
$$\frac 1 2 \sin2\theta(B^2-A^2) + AB\cos2\theta\cos\delta = 0$$
Edits made.
Assuming your final equation is correct, you've done the hard part. You just hit a 'blind spot' for the final simple steps:
$$\sin2\theta(B^2-A^2) = -2AB\cos2\theta\cos\delta$$$$\tan2\theta=\frac {2AB\cos\delta}{(A^2-B^2) }$$$$\theta=\frac 1 2 \left[ \tan^{-1}\frac {2AB\cos\delta}{(A^2-B^2) } \right]$$Being a bit picky, I'll also note that the question describes ##\vec J## as a 'Jones matrix, but this should be 'Jones vector'.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
