Rotation, Conservation of Energy, Power
In summary: Back to the original problem: it takes no work (and therefore requires the expenditure of no power) to keep a body rotating in the absence of friction. It is a body in motion remaining in uniform motion. But friction is acting on...
jtw2e
27
A rotating uniform cylindrical platform that forms the base of carnival ride has a mass of 248 kg and radius of 4.8 m. The platform slows down from 4.6 rev/s to rest in 14.9 s when the motor is disconnected.
Determine the power output required to maintain a steady angular speed of 4.6 rev/s. (hp)
I have KEi = Eloss
All I've been able to do so far is find the initial KE(rotational) = 41286.86J.
This would equal the Energy lost. I know it shouldn't take this amount just to keep it going though. It should take a smaller input of energy to keep it rotating at 4.6rev/s (or 28.9 rad/s).
Just a bit stuck on this one :(
In the absence of friction or other dissipative forces, it will take no energy to maintain the constant rotational velocity.
Do you see how to use the given information to find the forces opposing the rotation?
It seems to me that whatever opposes rotation is the Ffriction. I guess it's a constant retarding force over the full 14.9s. But I don't really see how to tie it together. Would the retarding force be a torque?
Yes: the friction acts to bring the disk to rest over those 14.9 seconds. You could view this as torque, but that's tricky: torque depends on distance from the axis of rotation, and the friction presumable acts all along the radius of the disk.
I often find it is helpful to consider what you can find, even if it does not look like it'll lead to the answer. What can you figure out given that the rotating disk goes from an energy of 41286.86 J to rest in 14.9 seconds?
... I can find that the angular acceleration [tex]\alpha[/tex] = [tex]\omega[/tex]/time = 1.9398 rad/s2.
But I think that's an instantaneous acceleration.
The only other thing I can think of is:
Ffriction = I[tex]\alpha[/tex]
All reasonable thoughts. (A caution: to use [tex]\alpha[/tex] = [tex]\omega[/tex]/time you need[tex]\Delta[/tex][tex]\omega[/tex] and [tex]\Delta[/tex]t. That gives the acceleration that caused that change in rotational velocity).
(Maybe it is just my monitor, but the Greek letters are all looking superscripted.)
The power generated by the force of friction to bring the disk from 41286.86 J to rest in 14.9 seconds is 41286.86 J /14.9 seconds. Do you then see how to use that to get the answer?
Fewmet said:
...The power generated by the force of friction to bring the disk from 41286.86 J to rest in 14.9 seconds is 41286.86 J /14.9 seconds. Do you then see how to use that to get the answer?
How does that work? Because Power is Work / Time ... not KE/t right?
I feel dumber every time I try. :/
No reason to feel dumb. Note that when I asked for what you could find out you came up with stuff that I had not been clever enough to think of.
You should, however, take this opportunity to fill a gap in your understanding. It looks like you are a little fuzzy about he relationship between work and energy.
Yes: power = work/time. I always emphasize with my students that work done to a body changes its energy by the same amount. If you do 200 J of work to lift a mass, you have increased its energy by 200 J. If I stop a baseball that was moving with a kinetic energy of 15 J, I did 15 J of work to it.
Back to the original problem: it takes no work (and therefore requires the expenditure of no power) to keep a body rotating in the absence of friction. It is a body in motion remaining in uniform motion. But friction is acting on the spinning disk in the problem, so you need to do work if you want to keep the disk rotating uniformly. What you have worked out is that friction does 41286.86 J of work to the disk in 14.9 s, which is a rate of 2770.930201 Watts. If we assume friction is a constant. You will always need 2770.930201 W to keep the disk going.
Make sense? Do you find the reasoning compelling? If not, I can say more. It is after midnight in Easter US, though, and I have a conference to attend in the morning. I am going to sleep. I'll check back here in before I leave.
FAQ: Rotation, Conservation of Energy, Power
What is rotation?
Rotation is the circular movement of an object around a fixed point or axis. It can be seen in everyday objects such as the Earth rotating around its axis, or a spinning top.
What is the conservation of energy?
The conservation of energy is a fundamental law in physics stating that energy cannot be created or destroyed, but can only be transformed from one form to another. This means that the total energy in a closed system remains constant over time.
How is power related to energy?
Power is the rate at which energy is transferred or transformed. It is calculated by dividing the amount of energy by the time it takes to transfer or transform it. In other words, power is a measure of how quickly work is done.
What is the difference between angular velocity and linear velocity?
Angular velocity is the rate of change of the angle of rotation of an object. It is measured in radians per second. Linear velocity, on the other hand, is the rate of change of an object's position in a straight line. It is measured in meters per second.
How does rotational kinetic energy differ from linear kinetic energy?
Rotational kinetic energy is the energy an object possesses due to its rotational motion. It is calculated using the moment of inertia and angular velocity. Linear kinetic energy, on the other hand, is the energy an object possesses due to its linear motion. It is calculated using mass and linear velocity. In general, rotational kinetic energy is greater for objects with a larger moment of inertia, while linear kinetic energy is greater for objects with a larger mass.
