Rotation - constant properties when met force is 0
In summary: Therefore, it cannot be used to answer the question of whether kinetic energy changes with time.In summary, if the resultant force acting on a body is zero, it does not necessarily mean that the kinetic energy does not change with time. Both the statements (A) and (C) are incorrect, while (B) and (D) cannot be determined without more information. This is because the change in kinetic energy depends on whether the forces acting on the body are conservative or not.
cupid.callin
1,132
this was a question in my book ...
If the resultant force (external) acting on a body is 0, then from an inertial, one can surely say that
(A) Linear momentum does not change with time
(B) kinetic Energy does not change with time
(C) Angular momentum does not change with time
(D) Potential Energy does not change with time
I know that (A) is correct and (C) (D) are wrong
i want to talk about (B)
According to energy conservation principle ...
If no external force acts and all the internal forces are conservative ... mechanical energy remains conserved (or constant ... please correct me ... but i guess conserved)
and like potential energy is changing so kinetic should also ...
But K = 0.5 mv2
so dK/dt = mv (dv/dt) = mva
of a =0 so K is constant ...
So what is really right?
Two of these three responses is correct. One is not.
why?
A is right of course
C is wrong as net 0 force can still have some torque and thus angular acceleration
D is wrong as suppose a body is coming down in a light with constant velocity v
net force of mg and normal rxn is 0 so acceleration is 0
but pot. energy dec
but also in this case v and thus kinetic energy is constant
If the potential energy is changing, obviously the corresponding field is exerting a force.
However, if the resulting force is zero, there must be another unspecified force opposing this.
The net result would be that the potential energy changes, but the kinetic energy is constant.
Note that this means that the total energy increases.
Btw, C is open for discussion.
You might say that the angular momentum in this case would be infinite, since there would be no acting radial force. Does it change?
The OP is correct about C. Consider a pure couple: Two forces acting on an object such that the vector sum of the two forces is zero but with the two forces applied at different points on the object. The net force is zero, but the net torque is not.
The OP is also correct about D. The OP's answer would have been wrong if both forces were known to be conservative forces. However, there is nothing in the problem statement that says that the two forces are both conservative. To the OP: Your perceived problem with statement B is that you are assuming mechanical energy is conserved, and that is only true in the case of conservative forces.
FAQ: Rotation - constant properties when met force is 0
What is rotation and how does it relate to constant properties?
Rotation refers to the circular motion of an object around a fixed point or axis. Constant properties, also known as moment of inertia, are the physical properties of an object that determine its resistance to rotational motion. In other words, rotation and constant properties are closely related because the latter describes how an object behaves when it is rotated.
What is the significance of a force of 0 in relation to rotation and constant properties?
A force of 0, also known as a balanced force, means that there is no net force acting on an object. In terms of rotation and constant properties, this means that the object is not experiencing any external forces that would cause it to rotate. This allows us to study the inherent properties of the object itself without the influence of outside forces.
How do constant properties change when a force is applied?
When a force is applied to an object, its constant properties may change depending on the magnitude and direction of the force. If the force is applied in the same direction as the rotational axis, the object's moment of inertia will increase. On the other hand, if the force is applied perpendicular to the rotational axis, it may cause the object to accelerate and change its angular velocity.
What is the relationship between rotation, constant properties, and torque?
Torque is a measure of the force that causes an object to rotate around an axis. In relation to rotation and constant properties, torque is directly proportional to the angular acceleration of an object. This means that the greater the torque, the faster an object will rotate. Constant properties also play a role in determining the amount of torque needed to cause a certain amount of rotation.
How are rotation and constant properties used in real-world applications?
Rotation and constant properties are used in various fields and industries, such as engineering, physics, and biomechanics. In engineering, they are used to design and analyze the performance of rotating machinery, such as turbines and engines. In physics, they are used to understand the behavior of rotating systems, such as planets and galaxies. In biomechanics, they are used to study the movements and forces involved in human and animal motion.
