Rotation: mass transfer and angular momentum conservation
In summary, the problem involves two drums of different masses and radii, with a layer of sand on the inner surface of the smaller drum. The sand starts to fly out at a constant rate and sticks to the outer drum. The goal is to find the subsequent angular velocities of the two drums. The approach involves applying angular momentum conservation, but there may be a continuum of solutions for the two angular velocities. The expression for torque on the inner drum is also questioned.
Avi Nandi
25
a drum of mass M[itex]_{a}[/itex] and radius a rotates freely with initial angular velocity ω[itex]_{a}[/itex](0). A second drum with mass M[itex]_{b}[/itex] and radius b greater than b is mounted on the same axis and is at rest, although it is free to rotate. a thin layer of sand with mass M[itex]_{s}[/itex] is distributed on the inner surface of the smaller drum. At t=0 small perforations in the inner drum are opened. the sand starts to fly out at a constant rate λ and sticks to the outer drum. Find the subsequent angular velocities of the two drums ω[itex]_{a}[/itex] and ω[itex]_{b}[/itex]. Ignore the transit time of the sand.
torque on drum A = [itex]\frac{1}{2}[/itex](M[itex]_{a}[/itex] + M[itex]_{s}[/itex]- λt)a[itex]^{2}[/itex]dω[itex]_{a}[/itex]/dt + [itex]\frac{1}{2}[/itex]λa[itex]^{2}[/itex]ω[itex]_{a}[/itex](t)
torque on drum B = [itex]\frac{1}{2}[/itex](M[itex]_{b}[/itex]- λt)b[itex]^{2}[/itex]dω[itex]_{b}[/itex]/dt - [itex]\frac{1}{2}[/itex]λb[itex]^{2}[/itex]ω[itex]_{b}[/itex](t)
now applying angular momentum conservation on the system I got a relation between ω[itex]_{a}[/itex] and ω[itex]_{b}[/itex].
I don't think that the Torque equations are needed. all you need to do is to conserve the angular momentum.
but i can not find any more relations between ω[itex]_{a}[/itex] and ω[itex]_{b}[/itex].
That can't be enough. For any given distribution of sand between the drums there will be a continuum of solutions for the two angular velocities that give the same overall angular momentum.
Avi Nandi, I'm unconvinced by your expression for torque on the inner drum. If a cart is traveling along and some of the load on the cart falls off, what force does that exert on the cart?
thank you haruspex and darkxponent.
FAQ: Rotation: mass transfer and angular momentum conservation
1. What is rotation?
Rotation is the circular movement of an object around an axis or center point. It is a fundamental concept in physics and is essential in understanding various phenomena such as mass transfer and angular momentum conservation.
2. How does mass transfer affect rotation?
Mass transfer refers to the transfer of material from one object to another. In terms of rotation, mass transfer can change the distribution of mass within an object, causing changes in its rotational speed and direction. This is due to the conservation of angular momentum, which states that the total angular momentum of a system remains constant unless an external torque is applied.
3. What is angular momentum conservation?
Angular momentum conservation is a fundamental law of physics that states that the total angular momentum of a system remains the same unless an external torque is applied. This means that if one part of a system gains angular momentum, another part must lose an equal amount of angular momentum in the opposite direction.
4. How does angular momentum conservation apply to rotation?
In the context of rotation, angular momentum conservation means that the total angular momentum of a rotating object must remain constant unless an external torque is applied. This is why changes in mass distribution or transfer of material can cause changes in the rotational speed and direction of an object.
5. What are some real-life examples of rotation and mass transfer?
There are numerous examples of rotation and mass transfer in everyday life. Some common examples include the rotation of the Earth around its axis, the transfer of mass between the Earth and the Moon, the rotation of a spinning top, and the transfer of mass between two colliding billiard balls. These examples demonstrate the conservation of angular momentum and how mass transfer can affect rotation.
