What Forces Affect the Rotation of a Submerged Disc?
In summary, the initial acceleration of the disc is 1.61 ft/s^2 and the final velocity after π/2 rotations is approximately 19.98 in/s.
JordanB87
1. A 20-lbf disc with diameter 18" and thickness of 3" is held static while completely submerged in water. Upon release of a lock, the disc experiences a torque from a torsional spring that causes rotation about its center of mass along the x/y axis (think coin toss, not wheel). If the spring is wound to 180-degrees with a constant of 10/π [lb/rad], what is the initial acceleration of the disc?
How fast is the disc moving after a quarter rotation?Attempt at a solution:
Spring force must overcome moment of disc and drag from water
20lbf = (20/32.2) slugs = 0.62 slugs
ιdisc=(1/4)Mr2 = (1/4)*0.62+(92) = 12.58
τ total = 180(π/180)(10/π) = 10 in-lbs
Initially: no velocity means no drag force. Thus...
τ total= ιdiscα
α = τ totaldisc = 10/12.58 = 0.79 rad/s2
Final Velocity at π/2 rotations
ρ = 0.036 [lb/in3]
CD = 1.17 for disc
A = πr2
Fdrag = CD(ρ/2)V2A= 1.17*(.036/2)*(0)2 = 0
velocity = π*diameter/2 <-- simplified as max velocity (at edge)
rdrag = r/2 = 4.5in
τ total= ιdiscα - Fdragrdrag
Am I on the right track?
Do I need to represent the drag force more qualitatively so that we can integrate to get the equation in terms of ω?
I am a bit lost at this point. Thanks for your time!
Hi there,
I would approach this problem by first identifying all the forces acting on the disc and then using Newton's laws of motion to determine the initial acceleration and final velocity.
So, let's start by listing the forces acting on the disc:
1. Weight of the disc (20 lbf)
2. Buoyant force from water (equal to weight of displaced water)
3. Torsional force from the spring
4. Drag force from the water
Now, let's use Newton's second law of motion (F=ma) to determine the initial acceleration and final velocity.
Initial acceleration:
Net force = Torsional force - Weight - Buoyant force
Net force = 10 in-lbs - 20 lbf + 20 lbf = 10 in-lbs
Net force = 10 in-lbs = mass * acceleration
Acceleration = 10 in-lbs / mass = 10 in-lbs / (20 lbf / 32.2 ft/s^2) = 1.61 ft/s^2
Final velocity:
To determine the final velocity, we need to consider the angular motion of the disc. We can use the equation ω = ω0 + αt, where ω0 is the initial angular velocity (which is zero in this case), α is the angular acceleration (which we calculated above), and t is the time.
Since we are looking for the final velocity after π/2 rotations, we can use the equation θ = ω0t + 0.5*α*t^2 to determine the time taken for π/2 rotations.
θ = π/2, ω0 = 0, α = 0.79 rad/s^2
π/2 = 0*t + 0.5*0.79*t^2
t = √(π/0.79) = 2.81 s
Now, we can use the equation ω = ω0 + αt to determine the final angular velocity:
ω = 0 + 0.79*2.81 = 2.22 rad/s
To convert this into linear velocity, we can use the equation v = ω*r, where r is the radius of the disc (9 inches):
v = 2.22*9 = 19.98 in/s
So, the final velocity of the disc after π/2
FAQ: What Forces Affect the Rotation of a Submerged Disc?
1. How does the rotation of a submerged disc affect the surrounding water?
When a disc is rotated while submerged in water, it creates a vortex that pulls water towards the center of rotation. This results in a circulation of water around the disc, causing a disturbance in the surrounding water.
2. What factors affect the rate of rotation of a submerged disc?
The rate of rotation of a submerged disc is affected by several factors, including the speed of the motor or source of rotation, the depth at which the disc is submerged, and the shape and size of the disc itself. The properties of the surrounding water, such as viscosity and density, can also impact the rate of rotation.
3. How does the rotation of a submerged disc impact the stability of the disc?
The rotation of a submerged disc can affect its stability in several ways. The vortex created by the rotation can cause the disc to move and shift in the water, potentially making it more unstable. Additionally, the rotation can also create drag force on the disc, which can impact its stability.
4. What are some real-world applications of the rotation of a submerged disc?
The rotation of a submerged disc has various applications in different industries. In fluid mechanics, it is used to study the effects of rotation on a body in a fluid. It is also used in the design of turbines and propellers for better efficiency. In the medical field, it is used to study the flow of blood in the human body.
5. Can the rotation of a submerged disc be used to generate electricity?
Yes, the rotation of a submerged disc can be used to generate electricity. This is commonly seen in hydropower plants, where water is used to turn turbines that generate electricity. The rotation of the disc creates kinetic energy, which can be converted into electrical energy through a generator.
9K
