Rotation of Earth and falling objects
In summary, the conversation discusses the direction in which a ball would land if released from the top of a tall building. It is agreed that the ball would land to the east, as the top of the building is moving faster than the bottom due to the Earth's rotation. The estimated distance the ball would be displaced to the east is around 3.5 centimeters.
ViolentCorpse
190
Hello everyone!
If a ball is released from the top of a very tall building, would it land ahead in the direction Earth is rotating (to the east) or would it lag behind i.e the Earth "moves out" from underneath it so it lands to the west? I think it should land ahead to the east since its tangential velocity is greater than that of the ground, but I'm not sure.
Thank you very much!
Yes, all things being equal, it would land to the east. As you point out, the top of the building is moving slightly faster eastward than the bottom and ball continues to carry this excess as it falls.
Back of the envelope...
For a 100 meter building the fall will nominally take 5 seconds (neglecting air resistance). The Earth is rotating at 2pi radians in just under 24 hours. With a 100 meter delta in radius, that's about 7 millimeters per second. Over a 5 second fall that would amount to about 3.5 centimeters.
Likes 1 person
AKA Coriolis Force.
Likes 1 person
Thanks both of you! Appreciate it. :)
Hello there! I can confirm that the ball will indeed land ahead in the direction of Earth's rotation (to the east). This is due to a concept known as the Coriolis effect. As the Earth rotates, it creates a force that deflects objects moving above its surface to the right in the Northern Hemisphere and to the left in the Southern Hemisphere. This means that the ball, being released from the top of a tall building, will be affected by this force and will land slightly to the east of its release point. This effect is also why hurricanes and other large-scale weather patterns tend to rotate in a clockwise direction in the Northern Hemisphere and counterclockwise in the Southern Hemisphere. I hope this helps to clarify your question!
Related to Rotation of Earth and falling objects
1. What is the Coriolis effect and how does it affect falling objects?
The Coriolis effect is the apparent deflection of objects moving on the surface of the Earth due to its rotation. This effect is caused by the Earth's rotation creating a centrifugal force that causes objects to appear to veer to the right in the Northern Hemisphere and to the left in the Southern Hemisphere. However, the Coriolis effect does not affect falling objects as their trajectories are determined solely by gravity and air resistance.
2. Is it true that objects fall faster at the equator due to Earth's rotation?
No, this is a common misconception. While the Earth's rotation does affect the Coriolis effect, it has no impact on the speed at which objects fall. All objects on Earth's surface, regardless of their location, will fall at the same rate due to the force of gravity.
3. How does the rotation of the Earth affect the trajectory of projectiles?
The rotation of the Earth does not have a significant effect on the trajectory of projectiles. While the Coriolis effect may cause a slight deviation in the direction of a projectile's path, this effect is negligible for most everyday situations. The main factors that determine the trajectory of a projectile are its initial velocity, launch angle, and air resistance.
4. Can the rotation of the Earth affect the height to which objects can be thrown?
The Earth's rotation does not have a direct impact on the height to which objects can be thrown. However, the rotation of the Earth does affect the speed at which objects are moving, which can indirectly impact the height they can be thrown. For example, objects thrown eastward (in the direction of Earth's rotation) will have a slightly higher initial velocity, allowing them to reach a slightly higher altitude than objects thrown westward.
5. How does the rotation of the Earth impact the Coriolis effect in different hemispheres?
The Coriolis effect is stronger in areas closer to the poles and weaker near the equator. This is because the Earth's rotation has a greater effect on objects at higher latitudes, where they are moving at a slower speed due to the Earth's curvature. In the Northern Hemisphere, the Coriolis effect causes objects to veer to the right, while in the Southern Hemisphere they veer to the left. The strength and direction of the Coriolis effect also vary depending on the speed and direction of the object's movement.
  • Classical Physics
  • Earth Sciences
  • Mechanics
